pine vr
with an extension cable  and a simple goggle mount for the lcd
a sensor set (gyro-meter, 3 axis accelerometer, etc etc).
then produce a stereoscopic view. and you have a VR system which costs 1/8th of the next least expensive option
you could 3d print the goggles but they probably wouldnt be super comfy ... should have counterweights opposite the screen to keep it from wanting to tilt forward
anyway to make a goggle harness that holds the lcd screen + an extension 40pin cable) should cost very little, infact you could mount the pine64 and battery behind the head, for a single helmet unit, putting 2 batteries in series would allow 1 to be hot swap-able.
  Pine 64 as Smart Speaker via Bluetooth Partymack711 0 5,426 06-21-2020, 03:28 AM
Last Post: Partymack711
  PINE as Wireless Repeater/Access Point? Dizzy49 7 18,535 04-01-2020, 09:38 AM
Last Post: ssgulliver
Video Best O.S. to use Pine as MediaCenter and Browser? marco97pa 12 26,225 03-05-2017, 01:08 AM
Last Post: abs0lut.zer0
  Pine tracker site like http://rastrack.co.uk? frewind 11 21,953 05-21-2016, 12:46 AM
Last Post: frewind
  Installing Pine A64 into a truck wesleyhowe123 1 5,330 05-09-2016, 01:24 PM
Last Post: ViperVi
  Pine 64 as a NAS media centre cerberusjvl 11 30,875 05-02-2016, 01:18 PM
Last Post: By-Jokese
  Pine A6+ with OpenVPN sprout 6 15,687 02-26-2016, 11:06 AM
Last Post: alg_42
  Host website on Pine server Ernst 6 14,171 02-24-2016, 07:42 PM
Last Post: jl_678
Question Pine 64 as an AP (Access Point)?? By-Jokese 1 6,493 02-21-2016, 09:09 PM
  pine A64 as midi computer urison 1 5,582 02-16-2016, 08:38 AM
Last Post: taros
