Host website on Pine server
Hi there,
I would like to use my Pine as a server to host my website. Does anyone know a easy way to do this?
I found a way to do it with a Raspberry Pi, can I use the same steps as they do?
http://www.instructables.com/id/Host-you...pberry-pi/
Funny you post this, I was just looking into it. Once we get a stable linux release, it should be possible.
Ya i think once a Linux distribution be able to run on pine64 we can do whatever we want to.
Sent from my HUAWEI Y530 using Tapatalk
By. Zoidiano0!
Installed:
LAMP: Linux , Apache2.4 , Mariadb, phpMyadmin, PHP5
Java 8 arm by oracle
Netbeans 8.1
chromium (uses way toooo much Ram)
Pine64 Head Unit Project.!
Hosting a website on PINE64 is likely one of the most popular uses for it! You'll be able to set up Apache, nginx, whatever you want!
Indeed, I am interested in this too.  I currently host a website on my Raspberry Pi 2 and am hoping that my Pine64 will be an upgrade.  In practice, it is actually quite easy, but you just need to ensure the appropriate packages are available.
The other item that is worth considering is running OwnCloud since you can basically create your own "Dropbox" like storage.  It works great on RPi if not a bit slow and I am hoping that it will run much faster on my P64.
(02-16-2016, 02:33 PM)jl_678 Wrote: Hi,
Nice, can you let me know if it works on your Pine and how you managed to do it?
Sure, no problem.
Sent from my XT1254 using Tapatalk
  Pine 64 as Smart Speaker via Bluetooth Partymack711 0 5,181 06-21-2020, 03:28 AM
Last Post: Partymack711
  PINE as Wireless Repeater/Access Point? Dizzy49 7 17,855 04-01-2020, 09:38 AM
Last Post: ssgulliver
  Mastodon instance \ Nextcloud Server fearg 1 7,102 03-31-2020, 08:18 PM
  Plex server arghne 59 183,206 07-06-2018, 10:36 AM
Last Post: Moshe.Vazan
  Turn your Pine64 into a music server with mpd JulianM 2 14,271 03-23-2017, 10:50 PM
  Plex server arghne 48 76,855 03-22-2017, 04:15 AM
Last Post: pineadmin
Video Best O.S. to use Pine as MediaCenter and Browser? marco97pa 12 25,268 03-05-2017, 01:08 AM
Last Post: abs0lut.zer0
  pine vr rxb 0 3,473 02-05-2017, 04:26 PM
Last Post: rxb
  Pine64 as NAS/Media Server VandaL.pr! 1 8,127 12-27-2016, 10:48 AM
Last Post: Luke
  3d printer server oldsmarracin 3 8,104 09-13-2016, 02:43 AM
Last Post: JAYJAYN
