Christmas pine64 2GB - DOA
Greetings all,
My brother gave me a pine64+ 2GB model for Christmas and I believe it's DOA.
Let me first start off that my power supplies certainly meet the requirements of this board with 2amp, 2.5 amp, and yes, I borrowed a 4.0 amp from my ws2812 strings to try.  The voltages are tight to usb 5v specs.
I'm a long time user of Pi boards.  All of the aforementioned power supplies work fine with my Raspberry Pis and so do the sdcards I've tried with the Pine.
I'm also a long time user of linux and consider myself advanced in the OS.  I use "dd" to dump and read often for other systems.  Every image I've dumped for the pine is fine.  Some of the images I've tried  create a fat for /boot, others have /boot in rootfs.
I tried several images and never got a thing, until I decided to hook up the debug port to a ttl adapter and this is what I got:
12/27/16-07:12:48 - HELLO! BOOT0 is starting!
12/27/16-07:12:48 - boot0 commit : 045061a8bb2580cb3fa02e301f52a015040c158f
12/27/16-07:12:48 -
12/27/16-07:12:48 - boot0 version : 4.0.0
12/27/16-07:12:48 - set pll start
12/27/16-07:12:48 - set pll end
12/27/16-07:12:48 - rtc[0] value = 0x00000000
12/27/16-07:12:48 - rtc[1] value = 0x00000000
12/27/16-07:12:48 - rtc[2] value = 0x00000000
12/27/16-07:12:48 - rtc[3] value = 0x00000000
12/27/16-07:12:48 - rtc[4] value = 0x00000000
12/27/16-07:12:48 - rtc[5] value = 0x00000000
12/27/16-07:12:48 - DRAM driver version: V1.1
12/27/16-07:12:48 - rsb_send_initseq: rsb clk 400Khz -> 3Mhz
12/27/16-07:12:48 - PMU: AXP81X
12/27/16-07:12:48 - ddr voltage = 1500 mv
12/27/16-07:12:48 - DRAM Type = 3 (2Big GrinDR2,3Big GrinDR3,6:LPDDR2,7:LPDDR3)
12/27/16-07:12:48 - DRAM clk = 672 MHz
12/27/16-07:12:48 - DRAM zq value: 003b3bbb
12/27/16-07:12:48 - DRAM single rank full DQ OK
12/27/16-07:12:48 - DRAM size = 2048 MB
12/27/16-07:12:48 - DRAM simple test FAIL.
12/27/16-07:12:48 - initializing SDRAM Fail.
It appears the RAM is bad and never attempts to access the card which explains why none of the imaging I've done ever worked.
I submitted a ticket to them (overdue), but at this point I don't think I'll get a response.  I sure hope they can do something. My brother, who doesn't have money waist and is disappointed as well.
This is my experienced thus far.
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 1,774 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 3,502 06-17-2021, 05:35 AM
Last Post: kqlnut
  Just discovered Pine64 ! - first Q philip_rhoades 4 5,818 04-29-2020, 10:13 AM
  A newest user in Pine64 Aliko 1 4,014 04-19-2020, 10:33 PM
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 152,144 01-15-2020, 12:46 PM
  Emails from pine64 received as spam by gmail Matan 2 5,825 08-21-2019, 08:30 AM
Last Post: Leiaz
  How to handle a Pine64 correctly gbjensen 6 16,455 03-28-2019, 11:43 PM
Last Post: InsideJob
Information Creating a NAS server in Pine64 javi_cala 4 8,396 01-21-2019, 02:03 AM
Last Post: bartes
  The 6 most common reasons why Pine64 won't boot Andrew2 109 210,690 10-11-2018, 11:35 PM
Last Post: Technolab88
  Pine64 installer way slow flashing Paraplegic Racehorse 2 4,564 01-10-2018, 04:05 PM
Last Post: dkryder
