What is on the Micro SC card that came with the board?
I opened th Micro SD card that was delivered with the Pine64 board
and saw the following list of files on the card.
Volume in drive Q is BOOT
 Volume Serial Number is 424A-49A2
 Directory of Q:\
05/07/2016  19:22    <DIR>          pine64
05/07/2016  19:22         1,076,704 initrd.img
02/11/2016  16:28               137 uEnv.txt
11/03/2016  15:46                 0 list_Q.text
               3 File(s)      1,076,841 bytes
               1 Dir(s)      39,806,976 bytes free
What are these files?
Why is the SC Card called BOOT?
If I download an image of Linux from Pine64.com to install it
on the SD card, must I first delete those files and format the SD Card?
(11-03-2016, 01:52 PM)clawinus Wrote: I opened th Micro SD card that was delivered with the Pine64 board
 Directory of Q:\
no,  just dd copy the image ( unzipped of course ) or use the Etcher program:
stay away from phoenix card
stay away from win32diskimager
  SOQUARTZ Compute module W does not fit Raspberry Pi CM4 dev board ihab 0 3,120 10-06-2022, 08:46 PM
Last Post: ihab
  How to boot from SD card on pinebook pro linux123 3 9,872 12-02-2020, 10:29 AM
Last Post: linux123
  micro sd card won't insert Samuel Venable 2 6,721 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 6,826 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 9,820 03-18-2020, 09:42 AM
  recommended micro sd card ? mronhb 91 291,129 03-03-2020, 11:34 PM
Last Post: siyatalerja
  Install OS on RAID1 thanks to dual SATA board? Thatoo 12 25,072 05-15-2019, 02:55 PM
Last Post: Thatoo
  My first Single Board! jjh221 4 10,335 04-09-2018, 06:52 PM
Last Post: jjh221
  sopine cluster board install Smurfbot 1 6,494 03-31-2018, 04:09 AM
Last Post: pfeerick
  eMMC card on adapter Malmgren 8 18,012 03-20-2018, 11:14 AM
Last Post: Malmgren
