My first Single Board!
Hey guys after a lengthy search for my first single board I settled on the Rock64 mostly because of the 4gb ram. I wish that it had wifi but a dongle works just as well and gives it a little more character. Anyways I just wanted to say hey and thank you for this board.
It has been many years since I have used linux so I have some reading to do tonight. The wiki seems very informative. Smile Also I have some future plans to bring many more people into the single board world and I hope that this community will help and welcome them.
I do have one question right now. I flashed my 64gb SD with jessie-minimal-rock64-0.5.15-136-arm64.img however it has no desktop enviroment. What is the easiest way for me to get a pretty looking and easy to use linux up and running quickly? Also security is a major issue. It must be safe.
Thanks,
J
(04-05-2018, 08:16 PM)jjh221 Wrote: Hey guys after a lengthy search for my first single board I settled on the Rock64 mostly because of the 4gb ram. I wish that it had wifi but a dongle works just as well and gives it a little more character. Anyways I just wanted to say hey and thank you for this board.
Thanks,
J
If you want to use a desktop environment with your Rock64 then please follow this thread. At the end of this month ayufan is aiming to release a stable 0.6.X OS image based on Bionic which will come with LXDE. For now however, you need to install the desktop yourself.
Security isn't an issue.
Great thanks Luke I'll have a read tonight. What about windows iot?
(04-07-2018, 02:06 PM)jjh221 Wrote: Great thanks Luke I'll have a read tonight. What about windows iot?
Windows IoT is NOT Windows OS, it is a dedicated function OS designs for IoT application. ROCK64 doesn't have Windows IoT or Windows OS build.
ok is there something that is user friendly that will work with the rock64 that has not been built by anyone? sorry for any confusion
  SOQUARTZ Compute module W does not fit Raspberry Pi CM4 dev board ihab 0 3,476 10-06-2022, 08:46 PM
Last Post: ihab
  Install OS on RAID1 thanks to dual SATA board? Thatoo 12 26,859 05-15-2019, 02:55 PM
Last Post: Thatoo
  sopine cluster board install Smurfbot 1 6,935 03-31-2018, 04:09 AM
Last Post: pfeerick
  What is the format that one should use for imaging SD cards on APINE64+2GB Board? Doryan 1 5,960 03-05-2018, 08:11 PM
  Which board to use? Dayve 0 3,832 02-18-2018, 06:31 AM
Last Post: Dayve
  Kodi on Rock64 board cenguix 2 11,939 02-02-2018, 03:05 PM
Last Post: stuartiannaylor
  What are these pins on PIN board? dims 1 5,399 01-15-2018, 11:21 AM
Last Post: Luke
  What is on the Micro SC card that came with the board? clawinus 1 6,229 11-03-2016, 02:33 PM
Last Post: MarkHaysHarris777
  Power Switch for Pine64 512MB Board MonarchOfLight 0 4,157 10-24-2016, 04:33 PM
Last Post: MonarchOfLight
  PineA64 512 reboot - board shut down indrajith 7 19,224 07-28-2016, 02:07 PM
Last Post: Ghost
