Smart home on PINE A64
Hi! I want use PINE A64 to controlled smart home. Its good idea or not??
1) PINE A64 can work with z-wave protocol?? If yes, what adapter I must use??
2) I want use camera in this project ... I can doing videostreaming with PINE A64 camera module to my Android phone via Wi Fi or maybe other protocol??
3) What smart home acesories can work with Pine A64???
4) I want use dynamic for voice in room?? What dynamic use better???
5) PINE A64 support OpenCV library???
(01-29-2016, 01:03 PM)SystemDi Wrote: Hi! I want use PINE A64 to controlled smart home. Its good idea or not??
There will be a z-wave module for the Pine A64, it is one of the accessories that will be available for purchase soon.
Z wave protocol can't use for video and audio! If I want use this I can transfer audio and video via wifi and data from sensor via z wave use only one PINE A64???
And if I need 3 camera module for my flat and streaming this video thread to android phone ... what I must do in this situation??? I cant use only one PINE A64 right???
Please help me cope with this
I understand that a Z-Wave module will be available.
Am I correct in assuming that the USB ( UZB Z-Wave stick will be compatible with the PINE 64.
Please confirm.
Regards
Dom
Please confirm.
Regards
Dom
I think that would depend on which particular Z-Wave USB stick you were using and which operating system you were running on the Pine. Unfortunately, Z-Wave is not an area I know much about.
Please confirm.
Regards
Dom
The Pine64 ZWave module using UART for communication. As my understanding, UZB deploy its own ZWave stack which is different that official ZWave stack, this means you needs UZB driver port over to Pine A64 platform before able to use.
What is the procedure to pair another z-wave device such as the Aeotec MultiSensor 6 with the Pine64/z-wave module?  I'm looking to have the pine64 my main home Automation controller with all the devices paired to it.
(02-08-2016, 08:46 AM)nchapman Wrote: What is the procedure to pair another z-wave device such as the Aeotec MultiSensor 6 with the Pine64/z-wave module?  I'm looking to have the pine64 my main home Automation controller with all the devices paired to it.
Different IoT software has their owns paring way. For openHAB, you can check at http://www.openhab.org.
  Pine 64 as Smart Speaker via Bluetooth Partymack711 0 5,448 06-21-2020, 03:28 AM
Last Post: Partymack711
  PINE as Wireless Repeater/Access Point? Dizzy49 7 18,587 04-01-2020, 09:38 AM
Last Post: ssgulliver
  AIY - Google Home jauyzed 3 11,619 11-05-2017, 01:16 AM
Last Post: dkryder
Video Best O.S. to use Pine as MediaCenter and Browser? marco97pa 12 26,280 03-05-2017, 01:08 AM
Last Post: abs0lut.zer0
  pine vr rxb 0 3,643 02-05-2017, 04:26 PM
Last Post: rxb
  Smart Mirror - Input Questions riahim 7 18,960 09-19-2016, 01:37 PM
Last Post: Lw64
  Home Automation. MokaMx_GDL_DE 1 5,386 06-30-2016, 02:58 AM
Last Post: bonterra
  Pushing notifications from home network to cell phone wahdooyah 0 4,601 05-30-2016, 08:25 PM
Last Post: wahdooyah
  Pine tracker site like http://rastrack.co.uk? frewind 11 21,990 05-21-2016, 12:46 AM
Last Post: frewind
  Installing Pine A64 into a truck wesleyhowe123 1 5,345 05-09-2016, 01:24 PM
Last Post: ViperVi
