Weatherproof case build
(10-02-2016, 10:21 PM)KablammoNick Wrote:
(10-02-2016, 10:10 PM)ltorsini Wrote:
(10-02-2016, 09:53 PM)KablammoNick Wrote: Hi, what are you using for Zigbee interface?
No ZigBee radio yet,  Tllim just had it reshipped.  We're testing enocean at the moment with the 300 USB on Android  but still early days.  I'm hoping openHAB will be a good option for the ZigBee kit.
Cheers, hoping to add Zigbee to my HASS build, but would rather an internal radio board to keep it neat... hopefully the one from Pine64 uses the Euler bus as the RPi bus is full with Z-wave board.
If I'm not mistaken you can connect the enocean radio via EULER, a little hardware hacking is needed but a pretty clean install should result. Good luck regardless.
Sent from my PINE A64 using Tapatalk
@tllim  you'll be happy to know that these are still running strong after all these years.  I have to admit that I still haven't gotten the ZWave board you sent me running, and since I am in the process of moving from OpenHAB to Home Assistant, I thought I might give it another run.  Do you know if anyone has successfully installed the board and gotten it running?
Big Grin Super Mario case [NOW WITH UPDATED STL-FILE (April 27.)] Tarjei85 37 77,589 07-23-2020, 05:31 AM
Last Post: devendraraju
  Made a case for the Pine64 with Audio DAC installed kodachrome 1 4,856 11-12-2019, 04:52 AM
Last Post: xalius
  playbox case ribbon cable too short pinoosh 7 15,191 02-22-2019, 03:24 AM
Last Post: GaryFunk
  Clear case PIne 64 with VESA100 LIPO , RTC holder, and mini fan holes killor 6 14,085 08-05-2017, 07:15 AM
Last Post: killor
  New Pine 64 Screen Case from C4Labs Dustin_C4Labs 11 23,144 07-18-2017, 10:39 AM
  A case with active cooling for 1Gb pine64 ishwest 5 12,318 06-28-2017, 04:05 AM
Last Post: ishwest
  Lego Case Kiryu 67 110,339 03-30-2017, 11:36 AM
Last Post: Luke
  Acrylic case with Lipo Holder and 2 Tactile push button included killor 9 16,385 10-24-2016, 08:18 AM
Last Post: killor
  Pine64 Layer case modmypi 2 6,497 10-04-2016, 02:45 AM
Last Post: modmypi
  Playbox case orderable? schindlb 8 16,744 10-02-2016, 08:20 AM
Last Post: schindlb
