How to set password for terminal
I would like to run several sudo commands in a terminal, which requires me to enter my password. But I was never prompted to enter a password, is there a default password? My pine phone came preinstalled (Manjaro-ARM, Release 21.03).
it is good idea to check some basics before installing new images, this is for future when you install something different.
https://forum.manjaro.org/t/manjaro-arm-...pro/144560
The premade users are:
User: manjaro
Password: 123456
almost all pinephone images use sudo system. it means that user password is given, not the root's password. although root user is usually not activated.
i think you have to edit the sudoers file
ezik
Note that you can use sudo -i to become root in the terminal, and you can also fully enable the root account by setting a password with passwd in that root shell, or with sudo passwd in a normal user shell.
  Setup My Pinebook 64 and Lost Password jersdayoff 5 5,871 05-01-2021, 10:29 PM
  Password Issue Doodenheimer 0 2,108 09-27-2020, 04:36 AM
Last Post: Doodenheimer
  forgot sudo password 20 jason20 8 10,166 09-26-2020, 07:29 PM
  debian user name & password Kaupy 1 3,908 10-08-2016, 12:18 AM
Last Post: MarkHaysHarris777
