Can't boot from eMMc with Armbian 23.8 Bookworm
Hello team!
I try to evaluate the platform based on:
  • Sopine Baseboard model A
  • Sopine A64 compute module
  • Armbian 23.8 Bookworm
There is no issue with SDCard boot.
But when I try to boot the same image from eMMC (32G), the process stopped when the kernel start.
Here is an extract of the log from the serial console:
Please go to the last line to see the last operation.
[10:40:49:671] U-Boot SPL 2023.07.02-armbian (Aug 31 2023 - 08:27:25 +0000)
[10:40:49:695] DRAM: 2048 MiB
[10:40:49:695] Trying to boot from MMC2
[10:40:50:402] NOTICE:  BL31: v2.9(debug):armbian
[10:40:50:402] NOTICE:  BL31: Built : 08:27:02, Aug 31 2023
[10:40:50:402] NOTICE:  BL31: Detected Allwinner A64/H64/R18 SoC (1689)
[10:40:50:402] NOTICE:  BL31: Found U-Boot DTB at 0x20ab818, model: SoPine with baseboard
[10:40:50:402] INFO:    ARM GICv2 driver initialized
[10:40:50:402] INFO:    Configuring SPC Controller
[10:40:50:402] INFO:    PMIC: Probing AXP803 on RSB
[10:40:50:402] INFO:    PMIC: dcdc1 voltage: 3.300V
[10:40:50:402] INFO:    PMIC: dcdc5 voltage: 1.200V
[10:40:50:402] INFO:    PMIC: dcdc6 voltage: 1.100V
[10:40:50:402] INFO:    PMIC: dldo1 voltage: 3.300V
[10:40:50:402] INFO:    PMIC: dldo2 voltage: 3.300V
[10:40:50:448] INFO:    PMIC: dldo4 voltage: 3.300V
[10:40:50:448] INFO:    PMIC: fldo1 voltage: 1.200V
[10:40:50:448] INFO:    PMIC: Enabling DC SW
[10:40:50:448] INFO:    BL31: Platform setup done
[10:40:50:448] INFO:    BL31: Initializing runtime services
[10:40:50:448] INFO:    BL31: cortex_a53: CPU workaround for 843419 was applied
[10:40:50:448] INFO:    BL31: cortex_a53: CPU workaround for 855873 was applied
[10:40:50:448] INFO:    BL31: cortex_a53: CPU workaround for 1530924 was applied
[10:40:50:448] SCP/INF: Crust v0.5.10000
[10:40:50:448] INFO:    PSCI: Suspend is available via SCPI
[10:40:50:448] INFO:    BL31: Preparing for EL3 exit to normal world
[10:40:50:468] INFO:    Entry point address = 0x4a000000
[10:40:50:468] INFO:    SPSR = 0x3c9
[10:40:50:961] ns16550_serial serial@1c28000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
[10:40:50:961]
[10:40:50:961]
[10:40:50:961] U-Boot 2023.07.02-armbian (Aug 31 2023 - 08:27:25 +0000) Allwinner Technology
[10:40:50:961]
[10:40:50:961] CPU:   Allwinner A64 (SUN50I)
[10:40:50:961] Model: SoPine with baseboard
[10:40:50:961] DRAM:  2 GiB
[10:40:51:022] Core:  73 devices, 22 uclasses, devicetree: separate
[10:40:51:022] WDT:   Not starting watchdog@1c20ca0
[10:40:51:022] MMC:   mmc@1c0f000: 0, mmc@1c11000: 1
[10:40:51:045] Loading Environment from FAT... Unable to use mmc 1:1...
[10:40:52:787] In:    serial
[10:40:52:787] Out:   serial
[10:40:52:787] Err:   serial
[10:40:52:803] Net:   eth0: ethernet@1c30000
[10:40:52:843] MMC: no card present
[10:40:52:843] ** Bad device specification mmc 0 **
[10:40:52:843] Couldn't find partition mmc 0
[10:40:52:843] starting USB...
[10:40:52:843] Bus usb@1c1a000: sun4i_usb_phy phy@1c19400: External vbus detected, not enabling our own vbus
[10:40:52:881] USB EHCI 1.00
[10:40:52:881] Bus usb@1c1a400: USB OHCI 1.0
[10:40:52:897] Bus usb@1c1b000: USB EHCI 1.00
[10:40:52:924] Bus usb@1c1b400: USB OHCI 1.0
[10:40:52:924] scanning bus usb@1c1a000 for devices... 1 USB Device(s) found
[10:40:54:067] scanning bus usb@1c1a400 for devices... 1 USB Device(s) found
[10:40:55:194] scanning bus usb@1c1b000 for devices... 1 USB Device(s) found
[10:40:56:329] scanning bus usb@1c1b400 for devices... 1 USB Device(s) found
[10:40:57:468]        scanning usb for storage devices... 0 Storage Device(s) found
[10:40:57:468] Autoboot in 1 seconds, press <Space> to stop
[10:40:58:507] switch to partitions #0, OK
[10:40:58:523] mmc1(part 0) is current device
[10:40:58:523] Scanning mmc 1:1...
[10:40:58:555] Found U-Boot script /boot/boot.scr
[10:40:58:602] 3259 bytes read in 5 ms (635.7 KiB/s)
[10:40:58:602] ## Executing script at 4fc00000
[10:40:58:602] U-boot loaded from eMMC or secondary SD
[10:40:58:602] Boot script loaded from mmc
[10:40:58:602] 155 bytes read in 4 ms (37.1 KiB/s)
[10:40:58:602] MMC: no card present
[10:40:58:602] ** Bad device specification mmc 0 **
[10:40:58:642] 41715 bytes read in 11 ms (3.6 MiB/s)
[10:40:58:642] Working FDT set to 4fa00000
[10:40:58:642] 3821 bytes read in 5 ms (746.1 KiB/s)
[10:40:58:642] Applying kernel provided DT fixup script (sun50i-a64-fixup.scr)
[10:40:58:642] ## Executing script at 45000000
[10:40:59:041] 18215274 bytes read in 395 ms (44 MiB/s)
[10:40:59:533] 22390792 bytes read in 476 ms (44.9 MiB/s)
[10:40:59:533] Moving Image from 0x40080000 to 0x40200000, end=417d0000
[10:40:59:733] ## Loading init Ramdisk from Legacy Image at 4ff00000 ...
[10:40:59:733]    Image Name:   uInitrd
[10:40:59:733]    Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
[10:40:59:733]    Data Size:    18215210 Bytes = 17.4 MiB
[10:40:59:733]    Load Address: 00000000
[10:40:59:733]    Entry Point:  00000000
[10:40:59:733]    Verifying Checksum ... OK
[10:40:59:861] ## Flattened Device Tree blob at 4fa00000
[10:40:59:861]    Booting using the fdt blob at 0x4fa00000
[10:40:59:882] Working FDT set to 4fa00000
[10:40:59:882]    Loading Ramdisk to 48ea0000, end 49fff12a ... OK
[10:40:59:912]    Loading Device Tree to 0000000048e2d000, end 0000000048e9ffff ... OK
[10:40:59:912] Working FDT set to 48e2d000
[10:41:00:344]
[10:41:00:344] Starting kernel ...
[10:41:00:344]
[10:41:03:989] <0x1b>[2J<0x1b>[3J<0x1b>[-1;-1fdone.
[10:41:04:014] Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
[10:41:04:014] Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems
It would be helpfull if somebody have any idea to solved this .
thanks for the support,
BR
(11-07-2023, 02:50 AM)francoispawlus Wrote: Hello team!
[10:40:50:961]
[10:40:50:961]
[10:40:50:961]
[10:41:00:344]
[10:41:00:344]
BR
this issue seems to be solved by using an older image: Armbian_23.02.2_Pine64so_bullseye_current_5.15.93.img.xz
So, there is/are bug/s in the current one (Armbian 23.8 Bookworm) that avoid the using of eMMC module!
See you!
BR
  Try to boot armbian 22.02 on SoPine baseboard adjivas 1 989 01-11-2023, 03:20 PM
Last Post: MNtinkerer
  Manjaro won't boot from EmmC adjivas 0 523 12-30-2022, 06:25 PM
Last Post: adjivas
  Armbian 22.02 Release Announcement TRS-80 0 1,132 02-28-2022, 05:00 PM
Last Post: TRS-80
  Warning: Boot regression in latest kernels (4.19, 5.10 etc.) kuleszdl 4 3,712 08-22-2021, 01:27 PM
Last Post: kuleszdl
  No HDMI output on standard Debian install / no boot sagada 2 4,708 09-06-2020, 03:54 AM
Last Post: kuleszdl
  SOPINE Network boot Ninazu 1 3,863 05-11-2020, 12:40 PM
Last Post: lbruno
  Armbian - Xenial (SOPINE) pineadmin 6 14,432 08-05-2019, 01:17 AM
Last Post: pineadmin
  Armbian Luke 1 4,040 07-07-2019, 03:53 AM
Last Post: igorp
  Trying to boot archlinux-minimal-sopine-20170708-1.img kris240376 0 2,577 05-25-2018, 10:30 AM
Last Post: kris240376
  Cannot boot into Xenial Mate Jacob5146 4 6,949 04-22-2018, 11:00 AM
Last Post: Jacob5146
