Cannot boot into Xenial Mate
Hello, I got my SOPINE board about 2 months ago and couldn't get it to boot then (same issue, blank screen upon power up). So as of this week I bought a high speed microSD, which before I assumed the reason for not booting was due to a slow SD card. But once again, blank screen  with the new card, and I'm staring to loose faith. Any help would be appreciated.
Sorry to hear you've been having problems. Just want to clarify some points to try and work out what the root issue is.
  • You're saying SOPINE board, so this is the sopine compute module on the sopine baseboard?
  • How are you powering the board?
  • How are you writing the SD card? Are you using the pine64 installer or etcher?
  • (The obligatory sanity check) Have you made sure you're using a sopine image, not one for the pine64?
  • What images have you tried? Can you give this one a try for me?
(04-20-2018, 05:46 PM)pfeerick Wrote: Sorry to hear you've been having problems. Just want to clarify some points to try and work out what the root issue is.
Hi, Yes I'm using a SOPINE compute module on the SOPINE baseboard, sorry for not clarifying.
I'm currently powering the board with the 5v 2A power adapter that is sold with the board (the combo pack).
I'm writing the images with etcher.
Yes haha I'm using the SOPINE images, not Pine64 images.
I have triend Android 6, Android 5, and Xenial Mate. I wish to use Xenial Mate, but have tried Android. Android 5 seems to be the only one that results in the Processor branding in the center of the screen with "Powered by Android" text bellow it, and nothing else happens. The other OS's result in a black screen, nothing else.
(04-20-2018, 06:14 PM)Jacob5146 Wrote: Yes I'm using a SOPINE compute module on the SOPINE baseboard, sorry for not clarifying.
I have tried Android 6, Android 5, and Xenial Mate. I wish to use Xenial Mate, but have tried Android. Android 5 seems to be the only one that results in the Processor branding in the center of the screen with "Powered by Android" text below it, and nothing else happens. The other OS's result in a black screen, nothing else.
Hehe... I should have mentioned the first one was a sanity check also Wink
Great, so that sounds like we *should* be able to rule out power and the microSD cards being corrupt... for now at least.
Since you're getting something from an Android image... it's also sounding like the card is compatible enough that the pinebook is at least booting. But I'm still wondering if the sopine/sopine baseboard still doesn't like the microSD you're using. I have had no end of issues with the Sandisk (red and grey) cards with pine64s... sometimes they work fine, sometimes they just refuse to play ball. If you're willing, get hold of a Samsung EVO microSD... they're the best performing card I'm come across for their price, aren't ridiculously expensive, and also seem to be the most compatible cards around.
Other than that, hopefully someone else has some ideas to try? If you want to debug it further, being able to connect to the onboard serial port should give some idea as to what is going wrong. Either this (with a suitable USB cable), some sort of USB to TLL Serial Console cable (a good idea to have one of these handy anyway) or any cheap USB to serial converter plus some connector wires will do the trick. Then you'll be able to see what the initial messages from uboot and the kernel are.
Yeah, I actually just had bought a SanDisk 16gb like 4 days ago hoping that it would be the fix. Is there anything else that could allow it to boot, I tired the .img you linked me to but I still had a blank screen saddly.
  Can't boot from eMMc with Armbian 23.8 Bookworm francoispawlus 1 503 11-13-2023, 04:12 AM
Last Post: francoispawlus
  Try to boot armbian 22.02 on SoPine baseboard adjivas 1 908 01-11-2023, 03:20 PM
Last Post: MNtinkerer
  Manjaro won't boot from EmmC adjivas 0 474 12-30-2022, 06:25 PM
Last Post: adjivas
  Warning: Boot regression in latest kernels (4.19, 5.10 etc.) kuleszdl 4 3,568 08-22-2021, 01:27 PM
Last Post: kuleszdl
  No HDMI output on standard Debian install / no boot sagada 2 4,588 09-06-2020, 03:54 AM
Last Post: kuleszdl
  SOPINE Network boot Ninazu 1 3,779 05-11-2020, 12:40 PM
Last Post: lbruno
  Armbian - Xenial (SOPINE) pineadmin 6 14,252 08-05-2019, 01:17 AM
Last Post: pineadmin
  SoPine/Pine64 LTS: Ubuntu Mate is not booting jaganteki 0 2,820 11-20-2018, 10:49 PM
Last Post: jaganteki
Exclamation Using LCD panel with Xenial Mate OS r.tanaka 1 3,819 09-05-2018, 11:55 PM
  Xenial Mate @ Sopine: no graphic acceleration & high CPU load AI_newsettler 0 2,337 08-11-2018, 10:26 AM
Last Post: AI_newsettler
