Thoughts on repairs for a Quartz64-B
I purchased new a Quartz64-b, and eventually found out that the Ethernet is faulty. ...after the 30 days warranty.
(I'm not a complete newb with SBC, but I got it, then ordered a Uart dongle later on, and that took its time to arrive and 30 days later...)
The errors for reference:
[  163.788898] rk_gmac-dwmac fe010000.ethernet end0: PHY [stmmac-0:01] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[  164.790182] rk_gmac-dwmac fe010000.ethernet: Failed to reset the dma
[  164.790836] rk_gmac-dwmac fe010000.ethernet end0: stmmac_hw_setup: DMA engine initialization failed
[  164.791683] rk_gmac-dwmac fe010000.ethernet end0: __stmmac_open: Hw setup failed
[  165.410902] rk_gmac-dwmac fe010000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0
[  165.504999] rk_gmac-dwmac fe010000.ethernet end0: PHY [stmmac-0:01] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[  166.513886] rk_gmac-dwmac fe010000.ethernet: Failed to reset the dma
So, a cautionary tale maybe? What to do?
Either: 1) wait - it may be a firmware issue. It hasn't been confirmed.
            2) repair it somehow? That seems very difficult.
            3) work around it. Wifi is working and a USB Eth --provided its NOT in the USB3 socket.
So, be careful. The quality control may not be there entirely. I don't know.
When you get it in the mail - test it ASAP, but then again you may not know all the faults with the device before the 30days is up .
Would I buy one again? ....probably not.
(08-01-2023, 11:37 PM)beepy Wrote: Hello,
Looking through an unrelated forum: https://forum.pine64.org/archive/index.p...13701.html
The RockPro64 seemed to have the same issue as I am having.
Maybe its specifically the RTL8211F Phy not playing well with the latest kernels - I dont know.
  Quartz64 seeming died Darin755 0 152 01-19-2024, 07:29 PM
Last Post: Darin755
  Quartz64 model a neither booting nor resetting without pressing reset button aleix 2 1,187 08-24-2023, 04:52 AM
Last Post: aleix
Question Li-Pol QUARTZ64 Model-B vs Model-A polrus 1 763 07-13-2023, 10:36 PM
  can't get quartz64-A working jyoung 14 4,485 04-29-2023, 04:41 PM
Last Post: diederik
  Trustzone support for QUARTZ64 capablegh 13 7,093 04-28-2023, 01:58 AM
Last Post: NCLI
  Booting Quartz64 Model B Jojo120120 14 7,658 01-23-2023, 03:31 AM
Last Post: balbes150
  quartz64 model b 2x20 max power proj964 1 1,554 10-23-2022, 05:32 AM
Last Post: CounterPillow
  quartz64 model b 2x20 pin header proj964 1 1,500 10-23-2022, 05:21 AM
  JTAG/SWD on Quartz64 model A capablegh 4 4,776 10-03-2022, 03:16 PM
Last Post: fatalfeel
  The "Should I buy a Quartz64 right now?" flow chart CounterPillow 3 4,082 07-13-2022, 09:50 AM
