The "Should I buy a Quartz64 right now?" flow chart
Hello PINEfriends,
I made a small flow chart to help people decide whether they should buy a Quartz64 Model A right now. I'll try to keep it updated as progress continues. I hope some will find it useful!
Note: This mainly applies to the Model A.
Updated 2022-10-21. Previous version
Updated 2022-04-19. Previous version
[Image: quartz%20flowchart%203.svg]
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
To me it's a yes and no at the same time.
If you have a serial USB, you can use it for the initial setup, and then continue via SSH.
After that, if you want to use it as a Monero node (with external SSD), buy it.
If you want to use it as a web server, better wait until a frozen release distro like Debian comes available, because Manjaro is really not something you want to use on a production server.
If you want to use it as a desktop PC, better wait until it becomes more daily driver ready.
母語は日本語ですが、英語も喋れます(ry
Does the "Do you need usb 3" question apply to usb 2 as well? Or is usb2 working without breaking sata?
(07-13-2022, 05:25 AM)Randomuser Wrote: Does the "Do you need usb 3" question apply to usb 2 as well? Or is usb2 working without breaking sata?
USB 2 works without breaking SATA, it's strictly just USB 3. Future revisions of the board will remove the SATA port and have USB 3 only.
Plebian GNU/Linux
  Quartz64 seeming died Darin755 0 140 01-19-2024, 07:29 PM
Last Post: Darin755
  Quartz64 model a neither booting nor resetting without pressing reset button aleix 2 1,167 08-24-2023, 04:52 AM
Last Post: aleix
  Thoughts on repairs for a Quartz64-B beepy 1 776 08-02-2023, 05:02 PM
Last Post: beepy
Question Li-Pol QUARTZ64 Model-B vs Model-A polrus 1 755 07-13-2023, 10:36 PM
  can't get quartz64-A working jyoung 14 4,406 04-29-2023, 04:41 PM
Last Post: diederik
  Trustzone support for QUARTZ64 capablegh 13 7,006 04-28-2023, 01:58 AM
Last Post: NCLI
  Booting Quartz64 Model B Jojo120120 14 7,590 01-23-2023, 03:31 AM
Last Post: balbes150
  quartz64 model b 2x20 max power proj964 1 1,545 10-23-2022, 05:32 AM
Last Post: CounterPillow
  quartz64 model b 2x20 pin header proj964 1 1,492 10-23-2022, 05:21 AM
  JTAG/SWD on Quartz64 model A capablegh 4 4,762 10-03-2022, 03:16 PM
Last Post: fatalfeel
