[30/11/2016] pine64-config
Pine A64 Configuration Tool [30/11/2016]
This tool is based on the raspi-config tool for the Raspberry Pi and it provides a straight-forward way to configure your Pine64.
Source code is available at https://github.com/Terra854/pine64-config
Prerequisites
You will need to have the xterm package installed in order to use this tool. You will also need to install newt (for openSUSE) or whiptail (for Debian/Ubuntu).
Note that for openSUSE, the tool and it's dependencies has been preloaded in the images.
Downloads
Github link
Installation/Update the tool
To install or to update this tool for your Pine64, you will need to run the following command:
sudo ./install.sh [ubuntu/debian/opensuse]
This will build the scripts that is relevant to your distribution of Linux and installs it to /usr/local/sbin.
Once it is installed, you can execute it with:
sudo pine64-config.sh
Enjoy!
Changelog
25/7/2016
- Initial Release
26/7/2016
- Added Debian support
2/8/2016
- Minor bugfix
3/10/2016
- Lot's of bug fixes and improvements.
- openSUSE is now supported.
- Added the ability to change the cpu governor
- Added a heath monitor (looping the pine64_health script)
6/10/2016
- Major bugfixes
30/11/2016
- Fixed the cpu governor feature
If you want to contribute or to file bugs, please feel free to post an issue or open a pull request on the GitHub page.
Donate BTC: 3Eav9uqXi8Nx1axb7QjK6xV4km4K9YGv9a
Very cool - Will give it a spin right away Smile
(07-25-2016, 08:46 AM)Terra854 Wrote: Pine A64 Configuration Tool [26/7/2016]
Prerequisites
You will need to have whiptail installed in order to use this tool (sudo apt-get install whiptail).
Installation
To install this tool for your Pine64, you will need to run the following command:
sudo ./install.sh
Enjoy!
Changelog
25/7/2016
- Initial Release
26/7/2016
Do note that this tool is in the beta stage. As such, this tool may not work as expected. If you want to contribute or to file bugs, please feel free to post an issue or open a pull request on the GitHub page.
Also, openSUSE support will soon be implemented in the coming weeks (You will get an error if you try to build the tool for it).
Thanks on the configuration tool and looking forward on the openSuse release.
Thumbs Up
That's a very nice idea mate...
Configuring the Pine64 with a similar tool to the Raspi.
This should be rather interesting to see if we can incorporate this into the next build.
Or we can try and include this and test it from our end before it goes into the next build.
Would this system work in Virtual machine? I mean the whole shebang?
Cheers,
vinodmenon80
Thank you!
But I couldn't install it
ERROR: No arguments specified (ubuntu, debian or opensuse)
You would know how to solve it?
And again,
THANK YOU!
(Sorry about my poor English)
(07-29-2016, 10:43 AM)Ophir Wrote: Thank you!
And again,
THANK YOU!
All you need to do is to type which distribution you are using (ubuntu, debian or opensuse) after the ./build.sh. (Eg. "./build.sh ubuntu" for Ubuntu). Do note that openSUSE is not supported at the moment, but it is there as a placeholder as I will be supporting it in a future release.
Doesn't work for me on lastest debian image. Did all steps and when i type sudo pine64-config.sh nothing happens.
(08-18-2016, 03:05 PM)Bart333 Wrote: Doesn't work for me on lastest debian image. Did all steps and when i type sudo pine64-config.sh nothing happens.
Just wondering, is the script located at /usr/local/sbin? Are there any error messages printed out after you ran it?
Hello everyone,
This tool has now been updated with a few new features.
Changelog:
Links are on the first post.
Hey guys, I have just uploaded an important bug fix to the repository. Please update your pine64-config tool to the latest version.
Links are in the first post.
  Programming languages support under PINE64 baryluk 6 20,533 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  Manjaro arm on pine64+ roel 2 10,569 10-19-2019, 05:13 AM
Last Post: roel
  Volumio for PINE64 Released mikelangeloz 11 38,875 03-22-2019, 09:25 AM
Last Post: llungster
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 6,616 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 10,050 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 56,637 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Official build procedure of ayufan pine64 r.tanaka 0 4,950 08-21-2018, 10:54 PM
Last Post: r.tanaka
  DKMS on kernel 3.10.107-pine64 obrienmd 5 14,458 06-21-2018, 05:45 PM
Last Post: evilbunny
  Gentoo for pine64 - longsleep kernel incoherent 0 5,650 12-09-2017, 08:14 AM
Last Post: incoherent
  Fedora Running On Pine64! cztian 26 59,641 10-26-2017, 05:51 PM
Last Post: gregjo
