PinePhone Pro not booting (Cap error!, pctl timeout)
today I tried to boot my PinePhone Pro, but it doesn't boot.
- Battery is charged (used external Charger, bought new battery)
- I can connect it to my PC and see the device in MASKROM mode
- no led or vibration is noticable
Trying to boot the phone connected with UART got me following lines.
U-Boot TPL 2021.10 (Oct 04 2021 - 15:09:26)
Channel 0: col error
Cap error!
Channel 1: LPDDR4, 50MHz
BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB
256B stride
lpddr4_set_ctl: channel 0 training failed!
lpddr4_set_rate: change freq to 400000000 mhz 0, 1
read_mr: pctl timeout!
Do someone have seen this, or maybe a solution to this problem?
Hi jealda,
I'm seeing exactly the same here; did you manage to fix it?
I've tried to install Tow-Boot from sdcard and pressing the RE button and still getting the same:
Tow-Boot TPL 2022.07
Channel 0: LPDDR4, 50MHz
BW=32 Col=10 Bk=8 CS0 Row=15 CS=1 Die BW=16 Size=1024MB
256B stride
Damn, looks like I too, joined the club of people with broken DRAM.
Booting on SPI: rk2aw + U-Boot's TPL on secondary:
rk2aw: booted version RK3399/pinephone-pro/2023-08-02/18:13:28
rk2aw: Booted from source 3 (SPI NOR) block=0x00
rk2aw: Will try booting boot block 0x01 on SPI NOR
U-Boot TPL 2023.07-rc6-megi-ppp-00050-g222aa75acee7-dirty (Aug 03 2023 - 15:09:37)
Booting from TowBoot on SD Card:
256B stride
SPI rk2aw + Rockchip's ddrbin on Primary:
rk2aw: Will try booting boot block 0x07 on SPI NOR
DDR Version 1.30 20230417
In
channel 0
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1 training pass!
change freq to 416MHz 0,1
Channel 0: LPDDR4,416MHz
Col error!!!
Cap error!
Channel 1: LPDDR4,416MHz
Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
no stride
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
Damn.
(07-11-2023, 10:50 AM)jealda Wrote: Do someone have seen this, or maybe a solution to this problem?
So, yes. I've joined the club of people seeing that.
(10-29-2023, 03:48 PM)jjardon Wrote: I'm seeing exactly the same here; did you manage to fix it?
Given that it's complaining of not being able to initialize a RAM channel, I'm starting to suspect that "managing to fix it" involves either a chip reflow workstation (for the DIY solution)  (Which is way beyond my reach) or a main board replacement (which is expensive).
  my pinephone melted norayr 6 948 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,118 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  various tricks to open the pinephone shengchieh 2 735 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 381 03-21-2024, 08:52 AM
Last Post: unrznbl
  pinephone keyboard + dock question tuxcall 7 2,888 02-05-2024, 03:17 PM
Last Post: wigan
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 56,404 12-17-2023, 11:42 AM
Last Post: robin.com.au
  Pinephone frame damages Uturn 2 1,036 10-23-2023, 02:49 AM
Last Post: Uturn
  PinePhone Keyboard KJ6OHG 11 8,191 08-23-2023, 03:25 AM
Last Post: Kali
  PinePhone constantly vibrating and won't take charge ImmyChan 5 5,500 07-23-2023, 03:49 PM
Last Post: kb-zealot
  Using optical drives with Pinephone cdforever 2 1,228 07-18-2023, 01:28 PM
Last Post: cdforever
