locked out on PIN screen
Pine64 Pro phone: Is there a recovery mechanism or do I need to desolder and reset something?
thanks.
The software PIN (the *nix user password) or the SIM card PIN? And why are you locked out, did you forget the PIN, or enter a wrong one too often?
For the software PIN, the lock out if you enter it incorrectly too often normally only lasts 5 minutes or so, depending on your distro's PAM configuration. So you can just wait it out. And if you do not want to have it happen again, configure your pam_faillock: https://man.archlinux.org/man/core/pam/f....conf.5.en. And the software PIN can always be recovered by reinstalling the operating system. If you got your PinePhone Pro recently (since July 2022), it came with Tow-Boot already installed, so just hold the volume up button on startup to put it into USB mass storage mode, then you can backup the data (if you did not encrypt it with a passphrase that you do not remember) and reinstall an operating system image from a computer.
The SIM card PIN is a different story, if you entered the wrong one too often, you have to unlock the SIM card with the PUK.
  Boot screen stuck at 'K' because of firmware deleted. poundantisec 9 5,279 08-28-2023, 11:38 AM
Last Post: fxc
Sad New PinePhone won't boot 9/10 times - Screen is on but stays black :( dante404 8 5,312 02-03-2023, 01:27 AM
Last Post: dante404
  My screen bottom side has loosed its tactile function arbocenc 1 822 01-06-2023, 10:02 AM
Last Post: britelite
  "PinenotePhone": Swap E-Ink Screen Onto Pinephone? britelite 0 676 01-03-2023, 06:17 PM
  Screen seems ok but no display UncleMeat 3 1,617 11-03-2022, 07:02 AM
Last Post: fxc
Question Black screen no matter the OS joseph303 2 1,512 07-19-2022, 01:07 AM
Last Post: joseph303
  Boot problem: wrong screen orientation Jetpac 6 3,802 07-18-2022, 12:47 PM
Last Post: fravoi
  Manjaro phosh no screen rotation sandspur 1 1,334 06-23-2022, 01:02 AM
Last Post: rapp
  Screen Lock Dinosaur1946 0 833 05-03-2022, 05:03 PM
Last Post: Dinosaur1946
  Cannot even create profile because screen won't rotate2 absolutenoob 5 3,621 02-28-2022, 01:00 PM
Last Post: Jetpac
