Cannot even create profile because screen won't rotate2
Hi, I posted a previous thread but i couldn't see it, or find it.
I am having a problem even setting up my profile in the opening user configuration. The screen is stuck in landscape and won't rotate so I cant see what I am typing. I can go back to theprevious screen to remove the keyboard, but none of my info saves.
I have also plugged in a keyboard, but still nothing helps. Do I need to flash a new version of the OS or something?
One of the SPAM preventive measures is to require new user's initial few posts to be approved.
That's why you could not see your prior post. When reviewing your posts, I deleted the first as it
became a duplicate, and your second included your attaching a keyboard as a test.
Arwen Evenstar
Princess of Rivendale
(12-10-2021, 03:17 PM)Arwen Wrote: One of the SPAM preventive measures is to require new user's initial few posts to be approved.
But the second thread is up, or is not up? I wasn't sure if you deleted that one too.
Yes, THIS thread is live.
Arwen Evenstar
(12-10-2021, 03:58 PM)Arwen Wrote: Yes, THIS thread is live.
Okay. Thank you.
One thing I have to add is that I am trying to do this on my pine phone without a SIM card installed yet. I don't know if that makes a difference.
(12-10-2021, 04:14 PM)absolutenoob Wrote: One thing I have to add is that I am trying to do this on my pine phone without a SIM card installed yet. I don't know if that makes a difference.
Hi absolutenoob,
i have the some problem... do you (or any other user) resolved this issue? thanks
  Boot screen stuck at 'K' because of firmware deleted. poundantisec 9 5,180 08-28-2023, 11:38 AM
Last Post: fxc
  locked out on PIN screen g40 1 636 06-07-2023, 10:20 PM
Sad New PinePhone won't boot 9/10 times - Screen is on but stays black :( dante404 8 5,256 02-03-2023, 01:27 AM
Last Post: dante404
  My screen bottom side has loosed its tactile function arbocenc 1 803 01-06-2023, 10:02 AM
Last Post: britelite
  "PinenotePhone": Swap E-Ink Screen Onto Pinephone? britelite 0 660 01-03-2023, 06:17 PM
  Screen seems ok but no display UncleMeat 3 1,583 11-03-2022, 07:02 AM
Last Post: fxc
Question Black screen no matter the OS joseph303 2 1,474 07-19-2022, 01:07 AM
Last Post: joseph303
  Boot problem: wrong screen orientation Jetpac 6 3,769 07-18-2022, 12:47 PM
Last Post: fravoi
  Manjaro phosh no screen rotation sandspur 1 1,315 06-23-2022, 01:02 AM
Last Post: rapp
  Screen Lock Dinosaur1946 0 816 05-03-2022, 05:03 PM
Last Post: Dinosaur1946
