My screen bottom side has loosed its tactile function
My screen bottom side has loosed its tactile function (I don't know if it's a hardware screen issue or just a bad connection of the screen). But, meanwhile, I have a problem to start my mobile because the OK button, when decrypting the device at the starting process (my device is encrypted) is very hard to touch (I should try dozens of times). I wonder if I can set:
an inversion of top/bottom sides, at mobile start, or always (when I'm in the graphical screes, auto rotate help me, there is not a major issue)
"Cancel" the bottom last centimeter of the screen.
Are there any settings file where I can modify these parameters?
if you can't find a solution and you just want to replace the screen, I think they're available in the store and there should be a tutorial somewhere: https://pine64.com/product/pinephone-5-9...ch-screen/
  Boot screen stuck at 'K' because of firmware deleted. poundantisec 9 5,012 08-28-2023, 11:38 AM
Last Post: fxc
  locked out on PIN screen g40 1 595 06-07-2023, 10:20 PM
Sad New PinePhone won't boot 9/10 times - Screen is on but stays black :( dante404 8 5,101 02-03-2023, 01:27 AM
Last Post: dante404
  "PinenotePhone": Swap E-Ink Screen Onto Pinephone? britelite 0 626 01-03-2023, 06:17 PM
Last Post: britelite
  Screen seems ok but no display UncleMeat 3 1,488 11-03-2022, 07:02 AM
Last Post: fxc
Question Black screen no matter the OS joseph303 2 1,420 07-19-2022, 01:07 AM
Last Post: joseph303
  Boot problem: wrong screen orientation Jetpac 6 3,657 07-18-2022, 12:47 PM
Last Post: fravoi
  Manjaro phosh no screen rotation sandspur 1 1,272 06-23-2022, 01:02 AM
Last Post: rapp
  Mute function on calls? scrwbigtek 0 713 05-30-2022, 12:52 PM
Last Post: scrwbigtek
  likely bug, volte does not work when operator side data blockage is activated zetabeta 1 1,222 05-21-2022, 03:03 PM
Last Post: zetabeta
