Pinephone KEYBOARD BATTERY ISOLATION.
Given the unnecessary complications of the pp-keyboard and subsequent disappointing user experience (e.g. it killed my Pinephone docking bar without warning, etc.) I was surprised to find there is still no convenient wiki-advice on the subject of ppkbd battery isolation. Does anyone know:
1) Is it practical to isolate the battery by adding an appropriate switch?
2) Can the keyboard operate without it's internal battery?
3) Would it be safe to use the Pinephone USB-C connector (charging &/or data) with the ppkbd battery disconnected?
1) Protecting the keyboard charger (not battery!) with an "ideal diode" module positively works and has been implemented successfully by several users:
https://www.reddit.com/r/PINE64official/..._keyboard/
https://www.youtube.com/watch?v=aXIw0i-c-Ms
Upon the modification, the USB-C charger can be plugged into either keyboard port (charges both the keyboard and the phone) or the phone port (charges only the phone). Docking dongle can be used on the phone port, both with or without the charger plugged into it. The situation with the dock plugged into the phone and the charger plugged into the keyboard should be avoided.
2) The keyboard operates strictly from the phone power. The keys are registered even if the internal keyboard battery is unplugged. The schematics is at
https://files.pine64.org/doc/PinePhone/P...211009.pdf
3) On a stock - not modified - keyboard, the answer is LIKELY NO. The keyboard internal charger IP5209 will be back-fed with ca 450 mA current, and may die in the process. Some users have reported exactly that (links above) while the others had some better experience.
Hopefully this helps.
  Case for Pinephone totilele 13 7,598 04-11-2024, 11:48 AM
Last Post: gramonyl
  keyboard case charging but not typing new2pinephone 18 5,996 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 10,611 01-14-2024, 03:34 PM
Last Post: acid andy
  PinePhone Dock with laptop? Mikey1977Y2J 2 677 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  I've added an I2C connector to the PP keyboard eugenr 0 455 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,281 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 479 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,294 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 548 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 646 10-21-2023, 02:55 AM
