key repeat with pinephone keyboard
My keyboard is repeating key presses. It occurs randomly with any key on the keyboard (this is not the top-row keys problem) and in any software. Typically it repeats a couple of dozen times, and I can get it to stop by hitting any key a few times.
What I tried:
- I did a clean install of manjaro phosh (internal, not the SD card).
- I tried both the kernel driver and the user space driver (pinephone-keyboard.disable_input in /boot/boot.txt; systemctl enable ppkb-i2c-inputd.service).
- Re-flashed the keyboard firmware.
None of these have had any effect.
I've never had trouble with the pin connections on my unit.
And it worked very well for about a year. I keep hoping a software update will fix it, but I am starting to doubt it's software, especially since I don't see anyone else having this particular problem.
Any thoughts on other things I could try?
  Case for Pinephone totilele 13 7,260 04-11-2024, 11:48 AM
Last Post: gramonyl
  keyboard case charging but not typing new2pinephone 18 5,799 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 8,620 01-14-2024, 03:34 PM
Last Post: acid andy
  PinePhone Dock with laptop? Mikey1977Y2J 2 641 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  I've added an I2C connector to the PP keyboard eugenr 0 428 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,178 10-22-2023, 08:43 PM
Last Post: Peter Gamma
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,240 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 520 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 618 10-21-2023, 02:55 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,024 10-20-2023, 04:11 PM
Last Post: mburns
