PinePhone Dock with laptop?
Wondering if anyone can help out. I have a Pinephone and an older version of the dock, however, I am in a remote location and need an ethernet port on my laptop. When plugging in the Pinedock into my laptop, the USB ports seem to work fine, but there is no power on the Ethernet port. Is there any way to make the dock worth on a laptop with Windows 10?
Thanks in advance for the help.
Can you try booting a GNU/Linux live image on your laptop? Any distro will do, really. Just put the live image onto an empty (or emptiable, i.e., with no important data on it) USB stick and boot it. If the distro recognizes the Ethernet port, you will know that it is a driver issue and that you need to find a Windows driver for the device if you want it to work under Windows. If it also does not work in GNU/Linux, then it is likely a hardware incompatibility.
(12-03-2023, 10:15 PM)Kevin Kofler Wrote: Can you try booting a GNU/Linux live image on your laptop? Any distro will do, really. Just put the live image onto an empty (or emptiable, i.e., with no important data on it) USB stick and boot it. If the distro recognizes the Ethernet port, you will know that it is a driver issue and that you need to find a Windows driver for the device if you want it to work under Windows. If it also does not work in GNU/Linux, then it is likely a hardware incompatibility.
Good idea... I have a Linux distro here somewhere on a separate SSD... Thanks for the suggestion. No luck on a Windows driver... but that would be awesome if I could find one.
  Case for Pinephone totilele 13 7,258 04-11-2024, 11:48 AM
Last Post: gramonyl
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,178 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 452 10-22-2023, 03:39 PM
Last Post: rotwang
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 518 10-21-2023, 07:50 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,022 10-20-2023, 04:11 PM
Last Post: mburns
  Mouse for the PinePhone? Peter Gamma 21 15,373 10-04-2023, 10:24 AM
  PinePhone Wallet Case Shane 5 5,037 09-17-2023, 12:52 PM
Last Post: J T
  KB: Using bus powered USB peripherals with the pinephone keyboard mounted docsunset 9 37,467 08-07-2023, 06:12 AM
Last Post: mikeb
  PinePhone flex breakout board with Grove female header jnpine 0 636 08-04-2023, 10:47 PM
Last Post: jnpine
  Pinephone Keyboard Connector dorkydev 0 650 07-19-2023, 04:40 AM
Last Post: dorkydev
