Mobian: squeekboard .yaml location
Smile
Greetings, new PPP mobian user here!
I'd like to add a custom keyboard layout to include the Shift Button on my keyboard but I can't find where the .yaml layouts are being saved.
Documentation says ~/.local/share/squeekboard/keyboards/ but I don't see a squeekboard file. Note I don't know much.
I thought maybe squeekboard is not installed and tried to built from git. Got stuck in meson _build. I started to download all dependencies it was asking for. Then it asked for gnome so I thought I am doing something wrong here. I've disabled gnome and enabled phosh back again.
Also, I see a squeekboard file in /usr/bin but can't open it. Is that from my attempt to install it?
A thank you to all the developers.
(04-15-2023, 03:31 AM)tookmeayear Wrote: Greetings, new PPP mobian user here!
see this ...
https://world.pages.gitlab.gnome.org/Pho...orial.html
layouts are hardcoded into binaries, however you can edit your own ones and copy to local user directory.
see this ...
thank you for the response. say I got one I want to use, do I copy it somewhere then gets picked up? I read before the documentation but I couldn't find that location
"The keyboard layouts are located in the subdirectory data/keyboards/ in the .yaml files"
probably here
https://gitlab.gnome.org/World/Phosh/squ.../keyboards
and location
~/.local/share/squeekboard/keyboards/terminal/
and you do not need to reboot, just deactivate keyboard and reactivate.
(04-16-2023, 06:05 AM)zetabeta Wrote: probably here
and location
I can't find those directories on my phone. note I didn't manage to install from the git repo but I assume is already installed
Actually I've just found my answer.. "the folder should be created if doesn't exist". https://forum.pine64.org/showthread.php?tid=9633
thank you
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 16 1,951 8 hours ago
Last Post: diederik
  Disable the GDM service in Mobian. mburns 0 471 11-25-2023, 10:19 PM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 894 11-18-2023, 08:21 AM
Last Post: crocspot
  Fix the Mobian Weather App mburns 0 504 11-07-2023, 10:01 AM
Last Post: mburns
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 716 11-07-2023, 09:44 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 608 10-14-2023, 11:57 AM
Last Post: mburns
  Mobian libnotify custom notifications MadameMalady 5 1,411 08-01-2023, 08:51 AM
Last Post: MadameMalady
  Mobian .desktop file creation MadameMalady 15 3,190 07-27-2023, 04:12 PM
  XFCE mobian running nicely but some oddities grump_fiddle_reinstall 0 811 07-01-2023, 08:18 AM
  [Mobian] : Battery consumption and OS compatibility freelectro 2 1,091 06-02-2023, 06:55 AM
Last Post: Fred Zyphal
