Unsuspend → Black screen
(06-14-2023, 01:32 AM)dante404 Wrote:
(05-09-2023, 07:50 AM)mdk Wrote: Noticed something else!
When the screen stays black the phone is hot.
It often happen while charging, maybe after hitting 100%.
Have to hard reboot.
Same here! Often in the morning (plugged in over night), it's dead...
Currently I THINK it doesn't happen (that often?) when my phone lays NOT completely on it's backside while charing over night but gets more 'ventilation'/fresh air (and so gets less hot)...
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
Currently I THINK it doesn't happen (that often?) when my phone lays NOT completley on it's backside while charing over night but gets more 'ventilation'/fresh air (and so gets less hot)...
My phone barely even gets warm with the keyboard case acting as both a larger sink and I never lay it phone side down. The device itself just never wakes from sleep.
I think this mornings update MIGHT have fixed it, but need more time to confirm
Edit: nope
(06-16-2023, 07:08 AM)Melechtna Wrote: My phone barely even gets warm with the keyboard case acting as both a larger sink and I never lay it phone side down. The device itself just never wakes from sleep.
Interesting. Mine gets really warm/hot when charging, and is always warm when 'dead' in the morning I think...
You're probably using a charger that pumps out close to the devices limit. I had a similar issue when I initially tried to charge it with a Pixel brick that was at the highest recommended limit of the device. Switching to one with a lower amperage, I think 0.5 amps less, it didn't overheat near as bad, With the keyboard case however, I can plug this charger into the case, and the lower one into the phone, and it makes it charge "faster", without the overheating issue either.
Interesting, I will have to look into this and probably get an other charger... Thanks!
@topic: It seems that the position (or 'cooling') of the phone doesn't really matter, I think now I was wrong on this. (Or... that has changed because of summer... Wink )
To be clear, it IS against the user manual for the keyboard case to do this, the dual charging I mean, but the device crashes if it's too low on battery, so that's why I do this sometimes. My device is one that has the "battery won't charge" issue with the case, but I'm working on it.
  Screen auto-rotation sensitivity mdk 0 286 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 669 06-24-2023, 01:55 PM
Last Post: freelectro
  Lock screen question: always squeekboard tuxcall 1 1,247 02-02-2023, 08:51 PM
Last Post: Haibara23
  [solved] Black screen at boot time mdk 0 1,026 01-13-2023, 03:33 AM
Last Post: mdk
  how to split screen? andrew907 2 1,557 08-08-2022, 09:38 AM
Last Post: andrew907
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 5 2,865 08-02-2022, 03:16 PM
Last Post: treebeard
  on screen keyboard woes vusra 1 1,263 07-18-2022, 03:29 AM
Last Post: vusra
  Giving certain audio apps priority on the lock screen and pulldown 3x5co 0 868 07-17-2022, 10:34 AM
Last Post: 3x5co
  Won't boot, black screen mdk 4 2,772 07-03-2022, 06:38 PM
Last Post: Chief
  Disable *automatic* on-screen keyboard iwakura_lain 0 947 06-11-2022, 09:49 AM
Last Post: iwakura_lain
