experience: pinephone keyboard drains pp battery faster?
Hi
i've had some weirdness with my pinephone keyboard. (might be my fault but just reporting/checking)
and i don't know if its because i did something wrong or something else.
Here is my experience:
with the keyboard attached the battery drains faster then without.
-without the keyboard my pp is still alive after a nights sleep
-with it's usually almost dead, the main battery completely drained and the keyboard battery very low
other things:
-the charging seems very slow through the keyboard
-pp also seems to run hotter more often with the keyboard attached (warmer to the touch then normal)
Now i have to admit, when i got the keyboard i was excited and hooked it to the pp and attached the dock + charger via the pp's usb-c (yup didn't read the manual lol)
Not sure if that is what caused this. but it could be.
has anybody else had this experience? is there a way to verify that i messed up the hardware? or any fixes?
thanks!
Unfortunately your keyboard's charging circuit has probably died. It's happened to quite a few of us if you look around the forum: https://forum.pine64.org/showthread.php?tid=16271
To test or fix the hardware you'd need to be good with a multimeter and soldering iron. I'd been thinking about buying a small charge controller circuit to try and repair mine but I don't have the time at the moment.
As my keyboard is definitely broken, I admit I now do charge through the phone's USB-C port, but do that at your own risk and I wouldn't leave it unsupervised in case the keyboard circuit overheats. My keyboard battery never charges up anymore but it still works as a keyboard when the phone is charged.
(02-11-2023, 12:39 PM)acid andy Wrote: Unfortunately your keyboard's charging circuit has probably died. It's happened to quite a few of us if you look around the forum: https://forum.pine64.org/showthread.php?tid=16271
Taking the keyboard apart, you can unscrew the board to take a look to see if the chip appears fried.
If so, you can find replacement keyboard mainboards for $9.99: https://pine64.com/product/pinephonepro-...mainboard/
- RTP
"In the beginner's mind there are many possibilities, in the expert's mind there are few." -Shunryu Suzuki
[ Pinephone Original | Pinetab v1 / v2 Enjoyer ]
Linux Device Privacy / Security Playlist
  Case for Pinephone totilele 13 7,597 04-11-2024, 11:48 AM
Last Post: gramonyl
  keyboard case charging but not typing new2pinephone 18 5,994 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 10,600 01-14-2024, 03:34 PM
Last Post: acid andy
  PinePhone Dock with laptop? Mikey1977Y2J 2 677 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  I've added an I2C connector to the PP keyboard eugenr 0 455 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,281 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 479 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,293 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 548 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 646 10-21-2023, 02:55 AM
