can the pinephone be operated with a stylus?
Question
i think it might be nice to operate the pinephone with a stylus, especially if you scale the apps down.
is that supported? what type of stylus would i need to buy to just operate the touch screen?
thanks!
Depends on the stylus. The touchscreen is capacitive so any stylus designed to work on capacitive touchscreens should work. That usually means having a sufficiently large conductive tip though, so not great for precision. It's not like the active Wacom type stylus, or a resistive touchscreen like we had on the OpenMoko or Psion.
thanks! then i can start looking for a capacitive compatible stylus and see if i like that
  Case for Pinephone totilele 13 7,241 04-11-2024, 11:48 AM
Last Post: gramonyl
  PinePhone Dock with laptop? Mikey1977Y2J 2 636 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,170 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 449 10-22-2023, 03:39 PM
Last Post: rotwang
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 515 10-21-2023, 07:50 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,021 10-20-2023, 04:11 PM
Last Post: mburns
  Mouse for the PinePhone? Peter Gamma 21 15,334 10-04-2023, 10:24 AM
  PinePhone Wallet Case Shane 5 5,031 09-17-2023, 12:52 PM
Last Post: J T
  KB: Using bus powered USB peripherals with the pinephone keyboard mounted docsunset 9 37,421 08-07-2023, 06:12 AM
Last Post: mikeb
  PinePhone flex breakout board with Grove female header jnpine 0 635 08-04-2023, 10:47 PM
Last Post: jnpine
