Slow download speed compared to upload
I tried remix Os last night. Everything worked right out of the box. However slow Ethernet speed is driving me nuts. I'm on Ethernet, no wifi module with my board. I have 75 Mbps at my home, no gigabit. I tested speed and it's around 1.5 Mbps download and 12Mbps upload. Not sure what is limiting the download  speed. Due to this I'm not able to stream at all.
Any help to resolve this is appreciated !!!
(07-14-2016, 06:20 AM)curiousgally Wrote: I tried remix Os last night. Everything worked right out of the box. However slow Ethernet speed is driving me nuts. I'm on Ethernet, no wifi module with my board. I have 75 Mbps at my home, no gigabit. I tested speed and it's around 1.5 Mbps download and 12Mbps upload. Not sure what is limiting the download  speed. Due to this I'm not able to stream at all.
what router do you have?
Does that matter ? Its Motorola sb6141
well yes because it has gigabit ethernet ports and uness you have specified 100mbit in the config of the router (if settings permit) then it will have issues due to the same bug as others are experiencing. If your router does not let you specify 100mbit mode you may try my temp fix if you have a spare ethernet cable until the drivers are sorted.  http://forum.pine64.org/showthread.php?tid=1739
I did implement your hack last night and voila !!! i have 90 Mbps now..
Thanks a ton: anarchyuk
Youtube and Kodi stream pretty flawless now. Sound is not great though, wonder what could be the issue.
  Latest Build - Where to download from? niksrocky 12 14,903 06-04-2016, 10:41 AM
Last Post: Danton
  RemixOS - slow download speed in OS mkyb14 9 12,685 05-16-2016, 04:53 AM
Last Post: Alex_TNT
  Video on how to upload Remix OS to Pine 64 Milkman 4 6,057 04-30-2016, 12:42 AM
