Manjaro pinebookpro images with kernel 5.7.19
(10-10-2022, 10:00 PM)wdt Wrote: >BTW, in 5.8.14 panel-simple is builtin, not a module
My pbp is from end 2019, came with mrfixit distro on emmc
(and more,,, a week after I got it, I got really sick for a month !!!)
At that time the manjaro distro had linux 5.7, early, without S3
(S2mem, STM). then there were a couple 5.7 updates and S3 could work
(and usbC video). Somewhere then an update to 5.8,,,, 2 versions
But the patch was dropped because it was a bit of a hack
And it never worked with nvme, it would start, then fail, and then wake
No luck with your kernel 5.8 image. The usb-c to HDMI functionality is broken. Although I don't see the black screen problem. And you're right about panel being built in.
I'm starting to wonder if there is a kernel module for HDMI missing on these "Linux" images. The "linux-pinebookpro" which is the 5.7.19 has no usb-c to HDMI issues but the display issue is there. Did Manjaro change a lot of stuff in their linux-pinebookpro image?
I can confirm that the usb-c to HDMI functionality is working on Manjaro with the kernel image linux-lts-5.15. This image is available in the repo currently.
In order to make the mkinitcpio script not fail when downgrading to kernel linux-lts, due to the missing panel_edp module just edit the file /etc/mkinitcpio.conf and add a "?" In front of the line "MODULES= panel_edp?", and that way the script is successful creating the initramfs file.
  Manjaro versions bad and good gilwood 0 247 02-12-2024, 05:03 PM
Last Post: gilwood
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,223 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 688 12-13-2023, 08:17 PM
Last Post: trillobite
  PinebookPro Display Corrupts/Cuts Out Twig 5 2,240 06-11-2023, 07:59 AM
  Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native) astr0baby 201 318,791 05-12-2023, 06:09 AM
Last Post: korreckj328
  Manjaro Plasma blinking cursor jcun4128 4 1,471 05-08-2023, 11:17 AM
  PBP blank screen after updating Manjaro Franko 6 2,016 04-01-2023, 07:55 AM
Last Post: hacknix
  Manjaro - which libdrm? hacknix 0 568 04-01-2023, 03:21 AM
Last Post: hacknix
  Partial boot after installing Manjaro on emmc regivanx 11 3,174 02-06-2023, 09:11 AM
  Broken usb-c to hdmi with kernel 5.18+ rfm83 6 2,874 01-22-2023, 09:55 PM
Last Post: rfm83
