Using multiple UART's on Rock64.
We are using one of the serial interface - UART_2 on the GPIO header pins for console. We wanted to use one more UART to communicate to another device.
From the pin diagram, there are 2 more UART's available. One set TX-RX on pins 15,18 and another set of TX-RX on pins 33,35.
We are only using EMMC and not using the SD card slot. Is it possible to disable SD card and configure it to be used for the UART.
We are using the Linux kernel from Ayufan - release-4.4.167.
How can we configure to use them appropriately. Is it possible to make the changes using dtb overlay.
Also what's the maximum baudrate that can be achieved on these UART's ? Currently the one used on UART_2 (console) is 1500000. Is this the maximum speed supported ?
  rAudio for Rock64 V2 shinzuka 9 1,515 06-05-2026, 06:22 AM
Last Post: shinzuka
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 12 18,522 03-07-2026, 11:04 AM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,046 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 5,893 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 11,793 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,161 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,336 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,353 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 86,101 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 110,012 09-01-2024, 06:05 AM
