PinePower Desktop USB-C port dead
I have a Desktop power supply that stopped supplying power through the USB-C port. Wireless and all the other ports work fine.
Has someone else encountered this issue? Is there any way to fix this? The wiki suggests the device is not designed to be opened.
(08-07-2022, 09:09 AM)qeek Wrote: I have a Desktop power supply that stopped supplying power through the USB-C port. Wireless and all the other ports work fine.
Do you mean you are unable to recharge the PinePhone64 ? If so YES. Mine has been plugged in for 5 days, and has gained 5% charge.
Either crap battery, or crap circuitry.
ALSO.
I am unable to shutdown the PinePhone64. It simply realises it's plugged into power and starts up. (Need to report this)
I don’t have a PinePhone. I’m talking about the desktop power supply which has some USB-A ports and a USB-C port. Unfortunately the USB-C port doesn’t provide a charge anymore. Can’t charge my PBP or any other device
Sent from my iPhone using Tapatalk
Hello, same here.
I've been using my Pinepower (4 ports + 1 USB-C 120W model) as a desktop charger for variety of devices (phone craddle, wireless headphones, 18650 cells charger) including my Lenovo E595 over USB-C.
Since month i've noticed that charging is being interrupted unless i wiggle cable. Happens, especially because i have official red USB-C to USB-C cable connected on one end to PP, other end connected to USB-C angle adapter.
This morning i've found my laptop's batter discharged and wiggling cable as well as replacing it didn't helped.
Laptop charges fine from it's dock, red cable charges my phone fine so last thing that left in common was PP.
I've ordered my PP at the end of May 2021 so device lasted over a year. Wondering is there any kind of warranty that i can  take advantage of.
edit: yes there is warranty, Device Warranty: 30 Days ;d
  Firmware Update for PinePower Desktop Power Cycling Issue TimothyRodriguez 1 109 05-03-2024, 12:53 AM
Last Post: Pavlos1
  Pine Desktop PowerSupply wont power on BSharp 5 1,850 08-29-2023, 08:06 AM
Last Post: chickenplusone
  PinePower 120w On/Off Switch rohtua 7 5,656 08-01-2023, 05:36 PM
Last Post: Callabra
  PinePower USB-C ports dead nbxmike 1 1,352 01-31-2023, 03:45 PM
Last Post: fxc
  Issues with PinePower Desktop superkamiguru 0 796 10-24-2022, 07:43 AM
Last Post: superkamiguru
  PinePower 65w - DoA or am I doing it wrong? CampGareth 10 8,293 10-04-2022, 09:02 AM
Last Post: hobbitus
  PinePower 120W Screen Issues t-3 3 1,873 09-26-2022, 05:14 PM
  on pinepower, pinecil stopped working.. sanderboer 1 1,145 09-23-2022, 03:47 AM
  Linux desktop on a Snapdragon 870 phone. Vasant 0 1,281 06-23-2022, 12:40 PM
Last Post: Vasant
  PinePower USBench concept: Usb C universal/lab power supply (=48V5A PD 3.1 trigger) ijsbeer 3 3,032 04-16-2022, 04:59 PM
Last Post: ijsbeer
