Pine Desktop PowerSupply wont power on
Anyone else have a dead desktop 120W power supply?  It would occassionally flicker when I first got it, but seemed stable enough (dumb, I know).  Now its just kaput.
I dont know if anyone has had one die and got it back running again?  I love the little unit was great for my Pinebook and Pi/Arduinos.
Wondering if I just got a bad unit that I should have returned?  or worth fixing?
Thank!
I would advise against opening a power supply, as this can be dangerous. Probably best to open a ticket under https://support.pine64.org
(04-23-2023, 02:31 PM)fxc Wrote: I would advise against opening a power supply, as this can be dangerous. Probably best to open a ticket under https://support.pine64.org
Thats probably a good call. Smile  Do you know if failure rate in them is high? or low?
Here at the community we don't really have insight in that. From people often asking in the chat etc. I would say issues are more common than with other Pine devices but I know that the power supply has upgraded internals over the OEM design to increase the life span.
The 120W PinePower failure rate is quite low.
I've never had trouble like this myself, contact support
Tower Defense
  Link USB power strips for a cluster? shanefe 1 237 04-02-2024, 11:11 PM
Last Post: evilbunny
  pine vacuum cleaner and door phone norayr 3 625 01-16-2024, 02:31 AM
Last Post: hanajijang
  Android OS that supports LCD touch panel (pine a64) Spekboy 0 384 01-14-2024, 01:41 PM
Last Post: Spekboy
  A post about a Pine-64 Wi-Fi ethernet router project board and enclosure? Omnios 1 623 09-21-2023, 07:52 AM
  [Article] Star64 JH7110: Power Up the Display Controller with U-Boot Bootloader lupyuen 0 680 09-02-2023, 10:13 AM
Last Post: lupyuen
  Is it possible to use Pine-64 board as a Mini PC such as BeeLink? Omnios 1 804 08-30-2023, 04:23 PM
  power/battery usage on risc-v vs arm64? zetabeta 1 793 08-28-2023, 01:23 AM
Last Post: alphonso
  Link USB power strips for a cluster? DevonBirch 4 3,458 08-10-2023, 09:11 PM
Last Post: halibutdreary
  Possible new Pine64 product - Pine Blue Ray DVD Linux tv box Omnios 5 1,545 07-24-2023, 03:21 PM
Last Post: Omnios
  Plans for higher Power PinePowers PMARC14 0 544 07-14-2023, 03:03 PM
Last Post: PMARC14
