wiping u-boot off sd card
i installed tow-boot  on pinephone beta edition but  it dosn't work
 so i found this
Quote:Q: I’ve installed Tow-Boot on my original PinePhone but it’s not working as described. A: The original PinePhone will always boot any u-boot on the SD card first. If you have an older Mobian image or another OS image on the SD card this may happen. Removing the SD card or wiping u-boot off it should cause Tow-Boot to work.
 but i don't find how to do it or where to find image without u-boot
 ezik
I described how I think it should work in the post below. Note that it's based on my reading of documentation linked further up the thread, and I haven't actually tried it.
https://forum.pine64.org/showthread.php?...#pid110012
(07-18-2022, 03:51 AM)wibble Wrote: I described how I think it should work in the post below. Note that it's based on my reading of documentation linked further up the thread, and I haven't actually tried it.
 thanks  i'll check it
 it's a new installation so i don't mind reinstall
 ezik
no it didn't work
the boot directory is empty
but the phone turn on with green light and vibrate every few seconds in endless loop
ezik
Quote:Since Danctnix (arch) switched to a gpt partition table from mbr in May of 2022 it installs u-boot at an offset of 128k instead of 8k, which means this command must be used instead
sudo dd if=/dev/zero of=/dev/[DEVICE] bs=32k seek=4 count=1
maybe that's why
i'll try this command when i get to linux computer
ezik
now tow-boot is booting  and the led turns aqua for a second
the archlinux from sd start to boot but fails and manjaro boot from emmc
ezik
 i tried an older image of arch but it doesn't boot as well
 i think now that those instractions wipe too much
 because it's for using the sd as storage and not for booting
 ezik
i read somewhere that u-boot has bootloader part and firmware part
and i think this dd command wipe both
ezik
  Can't boot on SD anymore LeNouveau 1 378 02-12-2024, 01:05 PM
Last Post: LeNouveau
  Does Ubuntu modify a Pinephone SD boot card? Peter Gamma 0 877 10-05-2023, 09:18 AM
Last Post: Peter Gamma
  External SD card not listed by Pcmanfm? Peter Gamma 1 1,553 08-22-2023, 12:22 PM
  Tow-boot headaches. antiwesley 3 1,518 04-30-2023, 05:03 PM
  problem with boot evaldas 2 2,253 03-17-2023, 06:21 AM
Last Post: gulshan212
  Article: NuttX RTOS for PinePhone: Boot to LVGL lupyuen 2 1,886 01-23-2023, 10:41 PM
Last Post: lupyuen
  tow-boot shulamy 2 1,675 09-08-2022, 12:33 AM
Last Post: shulamy
  Device memory full on multi-boot SD card Peter Gamma 4 2,754 08-27-2022, 10:03 AM
Last Post: Eugo
  Change tow-boot boot order or otherwise make Mobian on uSD the default? allworlds 3 2,460 05-04-2022, 06:27 PM
Last Post: allworlds
  Quick and easy bootloader option for JumpDrive on external SD card? Peter Gamma 5 2,732 05-02-2022, 06:57 AM
