11-22-2022, 01:49 PM
when I record any operating system, pinephone does not turn on, neither the led nor the screen lights up.
problem with boot
11-25-2022, 01:45 PM
(11-22-2022, 01:49 PM)evaldas Wrote: when I record any operating system, pinephone does not turn on, neither the led nor the screen lights up. That can have multiple causes, e. g. a drained battery or a corrupted installation. The LED and the screen backlight isn't used early in the boot process, which means if the installation got corrupted you won't see any error message or LED activity. Best if you put Jumpdrive on a microSD card and try to boot that. You can download Jumpdrive from https://github.com/dreemurrs-embedded/Ju...one.img.xz. Please let us know if there is any question or issue and if that worked.
03-17-2023, 06:21 AM
Hello this is Gulshan Negi
Well, if your PinePhone is not turning on when you try to record an operating system and the LED or screen does not light up, there may be several possible reasons for this. These include issues with the battery, operating system, SD card, connection, or hardware. To troubleshoot the issue, it's important to check each of these components and try different solutions, such as trying a different operating system or SD card, checking the connection, and consulting online resources or forums for guidance. If none of these steps work, you may need to contact the manufacturer or a qualified technician for assistance. Hope you are clear now. Thanks |
Can't boot on SD anymore | LeNouveau | 1 | 346 |
02-12-2024, 01:05 PM Last Post: LeNouveau |
Does Ubuntu modify a Pinephone SD boot card? | Peter Gamma | 0 | 850 |
10-05-2023, 09:18 AM Last Post: Peter Gamma |
Tow-boot headaches. | antiwesley | 3 | 1,501 |
04-30-2023, 05:03 PM Last Post: Kevin Kofler |
Article: NuttX RTOS for PinePhone: Boot to LVGL | lupyuen | 2 | 1,861 |
01-23-2023, 10:41 PM Last Post: lupyuen |
tow-boot | shulamy | 2 | 1,658 |
09-08-2022, 12:33 AM Last Post: shulamy |
Device memory full on multi-boot SD card | Peter Gamma | 4 | 2,717 |
08-27-2022, 10:03 AM Last Post: Eugo |
wiping u-boot off sd card | shulamy | 6 | 2,923 |
08-17-2022, 03:38 AM Last Post: shulamy |
Change tow-boot boot order or otherwise make Mobian on uSD the default? | allworlds | 3 | 2,437 |
05-04-2022, 06:27 PM Last Post: allworlds |
Problem Flashing the modem Firmware | loreson | 0 | 1,154 |
12-22-2021, 10:31 AM Last Post: loreson |
Multi boot issue | generaluser | 4 | 3,270 |
10-06-2021, 07:45 AM Last Post: generaluser |
