SD card add-on from Pine (reduced size)
I purchased a 32GB MicroSD card along with my Pine board as an add-on item, and it came with the board. I found it to have only 27GB of space and so obviously I am unable to add any 32GB OS image on it. The card has no brand name on it and I am not sure how to "resize" or increase the size to 32GB. Now I did the 1024/1000 math and it just doesn't add up. If I had purchased the card elsewhere I wouldn't be complaining. I purchased it from Pine/Backerit. Can someone tell me how I go about now? Thanks in advance!
Srivats
(07-09-2016, 12:51 AM)nighthawk7 Wrote: I purchased a 32GB MicroSD card along with my Pine board as an add-on item, and it came with the board. I found it to have only 27GB of space and so obviously I am unable to add any 32GB OS image on it. The card has no brand name on it and I am not sure how to "resize" or increase the size to 32GB. Now I did the 1024/1000 math and it just doesn't add up. If I had purchased the card elsewhere I wouldn't be complaining. I purchased it from Pine/Backerit. Can someone tell me how I go about now? Thanks in advance!
Srivats
Are you sure it is not pre-loaded with an operating system that is taking up some space? Your PC may not recognise the OS if you insert the microSD into it, because Android/Remix/Linux-based OSs all use an ext type filesystem which is not natively recognised by Windows, I think. Instead, Windows will probably ask you if you want to format the card.
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,704 08-07-2022, 10:47 AM
Last Post: commiecam
  How to boot from SD card on pinebook pro linux123 3 6,090 12-02-2020, 10:29 AM
Last Post: linux123
  pine store paulhide 1 3,207 09-17-2020, 04:13 AM
Last Post: bcnaz
  micro sd card won't insert Samuel Venable 2 4,477 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 4,383 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 6,472 03-18-2020, 09:42 AM
  My optimal software configuration for pine A64(+) 2Gb Alkemyboy 3 4,642 03-18-2020, 08:41 AM
  recommended micro sd card ? mronhb 91 213,350 03-03-2020, 11:34 PM
Last Post: siyatalerja
  Pine HDMI -> DVI monitor Pineapple 4 7,805 09-10-2019, 11:28 AM
Last Post: Pineapple
  PINE A64+ 4K Media Computer RWL 4 6,887 11-08-2018, 04:20 PM
Last Post: mindwave
