Using Android and the Playstore
I have a couple questions about Android.
1. It looks like the latest image for Android 9, SD card is from 2019. Have there been no updates since then? Or has support dropped off?
2. Is there any reason to choose an older version (7, 8)?
It looks like I have to do some work to install the Playstore, whichever version I use. I don't normally use Android but there are a few apps I would like to try. I might be able to set something up with a Linux distribution but it would probably be a lot more work than installing a couple of apps.
  Android images for RockPro64 BitAnnihilator 5 16,653 06-04-2024, 11:05 PM
  Difficulty installing Android on Rockpro64 spammycheese 0 5,376 02-17-2023, 05:31 AM
Last Post: spammycheese
  Slash TV Android for RockPro64 Wizzard 12 22,917 04-24-2022, 08:13 AM
Last Post: Rocklobster
  DRM support in Android Wizzard 2 6,927 02-03-2022, 09:16 PM
Last Post: Johnmo89
  Install Playstore on Android 8.1.0 Domo 14 43,325 04-16-2021, 02:13 AM
Last Post: Wizzard
  Install Playstore on Android 7.1.2 Domo 6 23,981 04-16-2021, 02:10 AM
Last Post: Wizzard
  Kodi crashing in Android 9 Wizzard 2 7,087 04-16-2021, 02:03 AM
Last Post: Wizzard
  Install Playstore on Android 9 image ddimension 18 46,587 02-13-2021, 12:52 AM
Last Post: chisteven
  RockPro64 line out/headphones in Android 9 Wizzard 0 5,746 11-20-2020, 04:15 AM
Last Post: Wizzard
  Android 9 drivers Firesped 1 6,481 11-19-2020, 12:39 PM
Last Post: Wizzard
