RockPro64 line out/headphones in Android 9
Ok, so it seems that line out/headphones jack works in Android 9 on RockPro, but I need to run this app before:
https://play.google.com/store/apps/detai...dset_testt
Without running it and clicking on Speaker Toggle there is no audio from audio jack. It seems that the headphones/line out cable is not detected.
So, how do I enable line out by default after boot? Now I have to run that Speaker Toggle after each boot when I want to use line out.
there must be some asound/alsa config some somewhere, but I was unable to find it.
I found this app better for that
https://play.google.com/store/apps/detai...eheadphone
It allows running after start and it can automatically set the desired output (although the outputs are reversed).
  Android images for RockPro64 BitAnnihilator 5 17,586 06-04-2024, 11:05 PM
  Difficulty installing Android on Rockpro64 spammycheese 0 5,638 02-17-2023, 05:31 AM
Last Post: spammycheese
  Using Android and the Playstore grobbs 0 5,947 06-04-2022, 12:18 AM
Last Post: grobbs
  Slash TV Android for RockPro64 Wizzard 12 24,191 04-24-2022, 08:13 AM
Last Post: Rocklobster
  DRM support in Android Wizzard 2 7,370 02-03-2022, 09:16 PM
Last Post: Johnmo89
  Install Playstore on Android 8.1.0 Domo 14 45,063 04-16-2021, 02:13 AM
Last Post: Wizzard
  Install Playstore on Android 7.1.2 Domo 6 24,850 04-16-2021, 02:10 AM
Last Post: Wizzard
  Kodi crashing in Android 9 Wizzard 2 7,505 04-16-2021, 02:03 AM
Last Post: Wizzard
  Install Playstore on Android 9 image ddimension 18 48,830 02-13-2021, 12:52 AM
Last Post: chisteven
  Android 9 drivers Firesped 1 6,836 11-19-2020, 12:39 PM
Last Post: Wizzard
