RockPro64 has no white led, nor will it boot past...
I have tried endless OS images, on both SD cards and eMMC, and am simply frustrated.
When I fire up a Debian buster image, it boots to the installer, gets all the way to the end, and then... Dies when it attempt to boot into the os for the first time.
The Armbian and ayufan images get to 'Flattened Device Tree blob at 01f00000' and 'Booting using the fat blob at 0x1f00000' and hangs.
There is no white LED at all as well.
Seems so strange as it grinds though so much doing the installer for Debian Bullseye.
Hoping this is just my own stupidity, and I am missing something obvious.
Thanks for the advice and guidance.
Cheers
Anjin
So.. I kept going backwards, and found an image that booted.  Read a pile of materials, and decided to start with the sigmaris u-boot updates to SPI.  Painless, and system booted a current Armbian without issues.  Also have a white LED now.[/url]
u-boot[url=https://github.com/sigmaris/u-boot]
(05-30-2022, 09:40 PM)AnjinMeili Wrote: So.. I kept going backwards, and found an image that booted.  Read a pile of materials, and decided to start with the sigmaris u-boot updates to SPI.  Painless, and system booted a current Armbian without issues.  Also have a white LED now.[/url]
Strange you couldn’t get the latest and Armbian Jammy found here to boot from SD. It really is just a case of downloading the image and writing it to an SD Card, popping it into the RP64 applying the power and you’re good to go. At least you’re up and running now but it looks like you spent a lot of time getting there. https://www.armbian.com/rockpro64/
  Installing Wifi drive for the RockPro64 John45595 0 313 02-10-2024, 11:32 PM
Last Post: John45595
  enble boot after power loss/restore dkebler 18 9,451 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 119,669 09-25-2023, 12:46 AM
Last Post: ChriChri
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 763 09-17-2023, 12:00 AM
Bug Broken boot: What am I missing? mkosarek 1 671 09-08-2023, 08:14 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 684 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,262 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 4,330 05-18-2023, 10:46 AM
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 894 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,331 04-06-2023, 02:46 PM
