PPP Phone rings with constant vibrate - turn off vibrate
I don't recall ever having this problem with my pinephone. I'll get a call and the phone will ring (not really a pleasant experience either). Along with this ring the phone continuously vibrates. Not like a small keyboard vibrate, but like like a vibrate that you can hear from another room. I would think that this is not a desirable  function in general. A ring is good enough, no need to wake up the neighbor ;-). Certainly, it has it's uses. For example, if you're in a theater and want to be notified when a call comes in, but that should be a silent type of vibrate (without a ring) that you feel in your pocket, just you.
Is there a way to turn off the vibrate for incoming calls, or at least reduce the vibrate "volume"? Is there some setting that controls the vibration characteristics for certain events? Same for the ring?
TIA for helping.
  Pine Phone Pro audio on phone calls: discussion, support and tips apink 42 12,518 12-26-2023, 02:14 PM
Last Post: apink
  Guide to Suitable Phone State Borealid 19 10,705 09-18-2023, 07:00 AM
Last Post: robocone
  Phone Attitude(Device orientation) lurkadillian 2 1,053 06-22-2023, 08:12 PM
Last Post: lurkadillian
  Pine Phone won't boot into recovery mode ninjapig26@gmail.com 3 1,783 02-18-2023, 06:14 PM
Last Post: fxc
  [Mobian] No return from locked phone arno_nuehm 1 1,030 02-06-2023, 07:57 AM
Last Post: arno_nuehm
  Phone shuts down unexpectedly Hobgoblin 3 1,614 12-20-2022, 01:11 PM
Last Post: Fish
  Sound completely gone with Mobian in Phone Call configuration EwigeBlumenkraft 2 1,774 11-11-2022, 09:18 PM
Last Post: apink
  PinePhone Pro Manjaro Plasma Mobile Beta 13 & No Audio with Phone Calls X0X0X0X0X0 0 1,099 11-02-2022, 02:09 PM
Last Post: X0X0X0X0X0
  Outgoing audio in phone calls gone linuxfreedom 6 3,345 10-25-2022, 08:40 PM
Last Post: apink
  Phone wont turn on with any SD Card inserted Ausfaller 3 2,420 07-21-2022, 10:20 AM
Last Post: Ausfaller
