[Mobian] No return from locked phone
Hello there,
using the 20230129 installer image for Mobian, the installation on the eMMC went through fine, but everytime the phone locks itself or is manually locked with the power button, there is no coming back to the login screen. The phone stays dark, but is still running, because changing the volume with buttons still works.
Has anyone encountered the same problem or a solution for that behaviour?
Thanks in advance!
Cheers!
Solved by luck... It seems that auto brightness control must not be enabled at the moment.
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 14 1,883 Yesterday, 05:40 AM
Last Post: diederik
  Pine Phone Pro audio on phone calls: discussion, support and tips apink 42 12,574 12-26-2023, 02:14 PM
Last Post: apink
  Disable the GDM service in Mobian. mburns 0 471 11-25-2023, 10:19 PM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 894 11-18-2023, 08:21 AM
Last Post: crocspot
  Fix the Mobian Weather App mburns 0 504 11-07-2023, 10:01 AM
Last Post: mburns
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 715 11-07-2023, 09:44 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 605 10-14-2023, 11:57 AM
Last Post: mburns
  Guide to Suitable Phone State Borealid 19 10,733 09-18-2023, 07:00 AM
Last Post: robocone
  Mobian libnotify custom notifications MadameMalady 5 1,410 08-01-2023, 08:51 AM
Last Post: MadameMalady
  Mobian .desktop file creation MadameMalady 15 3,186 07-27-2023, 04:12 PM
