Customized Sway on Pinephone
This is running on a Pro but it should run just fine for Pinephone. Spent most of my weekend working on this, the dot files are in the comments of the post.
https://www.reddit.com/r/unixporn/commen..._pro_sway/
That looks great!  Thanks for sharing all the files involved.  Did you start from a barebones arch install or build on top of something like the plasma mobile arch image?
I like the idea of switching from sxmo to just plain ol' arch with sway but am uncertain about what all would need to be installed to get the phone components working.  Would love to hear some more details about where you started from with this.
(05-21-2022, 04:01 AM)mr_growl Wrote: That looks great!  Thanks for sharing all the files involved.  Did you start from a barebones arch install or build on top of something like the plasma mobile arch image?
Thanks! I've been doing some updates to make it more user friendly (see merge requests on the GitLab page). I started from Phosh and added Sway and gdm. Then I disabled Phosh and enable gdm so that way I could decide what to log in to. That way I didn't have to install everything from scratch. Also, there are a few things not on that GitLab page that are helpful. If you want to open an issue there about other files that would be helpful, I can get to that when I'm at my computer.
Plasma Mobile currently has an intermittent bug about not being able to answer the phone but I think when that gets addressed I'll do the same but with Plasma Mobile instead of Phosh just because I like their apps way more.
Compared to Phosh I've noted a fairly significant increase in my battery life in the Pro (maybe 20% better battery life), so that's nice as well.
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 3 10,217 01-09-2025, 05:02 AM
  LibreOffice usable with Arch Linux on the Pinephone? Peter Gamma 2 4,178 07-28-2024, 05:12 AM
Last Post: Peter Gamma
  Pinephone with KDE Plasma stuck at K logo after update Daniello 0 2,246 06-20-2024, 01:52 AM
Last Post: Daniello
  Pinephone error system-generators/ostree-system-generator failed with exit status 127 Daniello 3 4,140 06-15-2024, 03:38 AM
  How to upgrade Phosh on Pinephone? ibid 1 3,408 08-18-2022, 09:02 PM
Last Post: mikehenson
  Delta Chat on Pinephone Emulti 1 3,936 07-31-2022, 07:32 AM
Last Post: magdesign
  Best Messaging client for pinephone? (arch-phosh) pineuser0 20 34,604 03-23-2022, 07:13 AM
Last Post: saba
  Arch image for Pinephone - where to get it? MikeMan 7 10,661 02-01-2022, 12:35 AM
Last Post: MikeMan
  Rootkit detector for Arch Linux on PinePhone tk1107 11 19,235 01-01-2022, 12:04 PM
Last Post: tk1107
  Emulation on Pinephone UBPorts CE Running Arch Linux ARM Plasma Mobile horme7 0 3,471 12-12-2021, 10:29 PM
Last Post: horme7
