How to upgrade Phosh on Pinephone?
Hi, I have local/danctnix-phosh-ui-meta 0.2.2 installed and local/phosh 0.17.0-1.
I have been unable to upgrade phosh to 0.20.0-1
Is this possible? When I run 'sudo pacman -Syu' it replies that there is nothing to do. Must I re-flash a whole new image? Or is there some way to upgrade my current installation?
WARNING This can cause problems.
These packages are on danctnix-testing server.
Update the phone as is:
sudo pacman -Syu
Restart the phone
sudo reboot
TURN ANIMATIONS ON
The animations can be turned on / off in the settings (Settings > Accessibility > Enable Animations).
add the danctix-testing to the pacman config
sudo nano /etc/pacman.conf
Add these lines to pacman.conf
[danctnix-testing] Server = https://p64.arikawa-hi.me/danctnix-testing/aarch64/
Sync the pacman databases
sudo pacman -Sy
update only the phosh and phoc. Danctix has other package on the test server that you may not want right now.
sudo pacman -S phosh phoc
Restart the phone
sudo reboot
remove the danctix-testing to the pacman config
Remove these lines to pacman.conf
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 3 10,317 01-09-2025, 05:02 AM
  LibreOffice usable with Arch Linux on the Pinephone? Peter Gamma 2 4,254 07-28-2024, 05:12 AM
Last Post: Peter Gamma
  Pinephone with KDE Plasma stuck at K logo after update Daniello 0 2,293 06-20-2024, 01:52 AM
Last Post: Daniello
  Pinephone error system-generators/ostree-system-generator failed with exit status 127 Daniello 3 4,238 06-15-2024, 03:38 AM
  stuck between phosh and plasma aular 0 2,556 02-27-2024, 05:55 PM
Last Post: aular
  How to find software app, on Arch Phosh? general_lee 5 9,239 10-15-2023, 10:12 PM
  Evolution no longer runs on Arch Phosh. Chief 2 4,244 10-17-2022, 07:22 AM
Last Post: Chief
  Scaling problem Arch Linux Phosh Chief 7 10,462 09-27-2022, 12:31 PM
Last Post: Chief
  Delta Chat on Pinephone Emulti 1 3,962 07-31-2022, 07:32 AM
Last Post: magdesign
  repository for arch-phosh oihantto64 8 13,852 06-27-2022, 03:00 AM
Last Post: shulamy
