Why not Atheros ath9k_htc for wifi?
I am not trying to speak for tllim, however my interpretation is that they cannot get them in quantity from known, reliable supplier.
As individuals, we can still get them off AliExpress (and similar) in small quantities, in fact this is what I am still doing to this day, and encourage others (who care about freedom) to continue to do the same.
Cheers,
TRS-80
Protocols, not Platforms
TRS-80, but I guess, in the phone, the wifi chip is soldered, so whatever I buy in AliExpress, as you are encouraging, I cannot use this in the phone (unless I have good soldering skills, which I don't have in fact).
Sorry for long delay, I was moving.
IIRC, the ath9k driver is for PCI/PCIe, where ath9k_htc driver is for USB based devices. So you would have to run it off of a USB hub or adapter, which would be sort of inconvenient for a phone. However, if you really wanted to...
You can still find the latter on AliExpress, eBay, etc. Search for chipsets like AR9271 or AR7010, etc. In Debian (Mobian) you will then need the firmware package firmware-ath9k-htc.
Cheers,
TRS-80
OK, this was my question too, lol. OK so we have to use a USB hub or adapter... You know, if this was attached to a docking station like the PinePhone keyboard is (remove the battery and back cover, plug in with pins), that would be cool. I am interested in the idea of an ergonomic convergence accessory for the PhonePhone. Put atheros or some other opened/liberated wifi in that by way of USB. Not only would we have linux-libre for ARM, we'd have a portable ergonomic keyboard.
Something a little bit like this.. https://www.youtube.com/watch?v=dqooxqrTTKU
But I guess it's a question of how to get it to communicate by USB.. Probably could have a piece that plugs in.
To the drawing board... >.>
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 542 02-17-2024, 04:15 PM
Last Post: vortex
  bluetooth wifi bugs aular 6 1,512 08-27-2023, 07:53 AM
Last Post: aular
  No wifi/bluetooth on multiple OS's Xxancap15 1 1,130 10-28-2022, 12:10 PM
Last Post: fxc
  Wifi no scan results - Bluetooth adapter not available emsyr 1 1,405 08-29-2022, 02:46 PM
Last Post: emsyr
  Did i break my wifi with the keyboard? captchasolver 5 3,191 02-10-2022, 03:39 PM
Last Post: pothos
  Wifi doesn't respond jmlich 6 4,186 02-04-2022, 06:50 PM
Last Post: bcnaz
  Suddenly WiFi signal strength is poor cinix 4 3,524 09-26-2021, 04:19 PM
Last Post: cinix
  Wifi/BT interface not detected aithal 17 14,807 05-30-2021, 11:10 AM
Last Post: Krasimir
  WIFI not available after anx7688 update failure frimmel 21 19,491 05-11-2021, 02:45 AM
Last Post: frimmel
Rainbow PinePhone WIFI: PineCone user installable? PineUser-1337331 2 2,527 01-28-2021, 01:03 PM
Last Post: PineUser-1337331
