Pinephone keyboard poor pogo pin connection
My Pinephone keyboard isn't connecting to the pogo pins well.  I've tried the shim method, but this only seems to raise the plastic edge of the connector section, rather than the connectors themselves, so didn't correct the issue.  Unless the shim can pass directly under the the connectors (which doesn't seem possible) I can't see how this method would help.  I've tried various shim materials, card, plastic, aluminium drinks can etc.  Experimented with multiple layers of shim etc.
Currently the keyboard only functions for me (with or without a shim) if I apply a little pressure on the rear of the case over the area of the pins.
I'm certain the phone and case are connected correctly, everything has clicked into place.  I could not apply any more pressure to the phone when seating it without risking cracking the display.
Is there an alternate workaround to this issue?
(03-08-2022, 12:00 AM)neil_swann80 Wrote: Unless the shim can pass directly under the the connectors (which doesn't seem possible)
I take no responsibility for that but... i'd say it is possible. I tried different shims cut off from plastic boxes recycled from plastic littery (some biscuits container, an olive container, yogurt box and so on...)
A 0.7mm thick shim made the back bulgy, a 0.15mm was too thin. In the end I cut a plastic rectangle of approx 16x10mm 0.37mm thick and managed to entirely slide it between the contacts and the back of the case using some 'plastic case openers' (the blue triangles from iFixit set). It is totally invisible and in my case it made the contacts fully reliable.
Amazing... thanks for replying.  You gave me the confidence to proceed. Using a spudger (plastic case opener) I was able to carefully lift the clips on the pogo connector section, then pass a blade under the section to break the adhesive.  A shim would then pass all the way under the contacts.  Two layers of aluminium drinks can worked for me.
I now have working keyboard.  Next job... add the 3D printed spacers to the number row!  Smile
  Case for Pinephone totilele 13 7,547 04-11-2024, 11:48 AM
Last Post: gramonyl
  keyboard case charging but not typing new2pinephone 18 5,961 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 10,265 01-14-2024, 03:34 PM
Last Post: acid andy
  PinePhone Dock with laptop? Mikey1977Y2J 2 667 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  I've added an I2C connector to the PP keyboard eugenr 0 452 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,270 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 470 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,282 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 539 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 640 10-21-2023, 02:55 AM
