distro with kernel support for DVB-T dongles?
Is there an image, preferably Debian or Ubuntu, with kernel modules for DVB-T dongles included?
In particular, I need dvb-usb-it913x and it913x-fe modules, but I do not see any dvb-related modules in /lib/modules in any of the images I have found.
(I wanted to use my Pine64 as a tvheadend-server for Kodi. It worked out of the box with my Raspberry pi, but it died recently and I wanted to replace it with something faster..)
Thanks.
https://www.pine64.pro/downloads/#Debian-Linux
should have support for your device right out of the box.
Only way to know is to give it try but since kernel 3.2 it has been supported Wink
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
(07-02-2016, 12:05 PM)lenny.raposo-pine64.pro Wrote: https://www.pine64.pro/downloads/#Debian-Linux
Are these different from those at http://wiki.pine64.org? Confusing, with several sites..
Anyway, I just tried the "Debian Base (3.10.102 BSP)" image and it is the same story Sad
That's a fourth or fifth image I have tried, so it looks like I will just have to buy another Raspberry pi...
  Programming languages support under PINE64 baryluk 6 18,862 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  PineA64+: Audio in 5.0 Kernel puzzles 6 14,873 11-13-2019, 09:41 AM
Last Post: roel
  Rockpro64 NFS root mount (kernel 4.20) - ethernet help? tenspd137 0 4,473 12-06-2018, 01:14 AM
Last Post: tenspd137
  NVMe and new kernel bjbb17 0 3,961 09-25-2018, 03:39 PM
Last Post: bjbb17
  Real-time linux kernel Artyom 45 110,721 09-11-2018, 01:08 AM
Last Post: zzwpine
  DKMS on kernel 3.10.107-pine64 obrienmd 5 13,183 06-21-2018, 05:45 PM
Last Post: evilbunny
  Kernel for A64 git longsleep 179 402,800 03-25-2018, 03:25 PM
Last Post: Luke
  AXP803 Battery Charger Support xalius 14 36,000 12-22-2017, 08:59 AM
Last Post: Velociraptor
  Gentoo for pine64 - longsleep kernel incoherent 0 5,212 12-09-2017, 08:14 AM
Last Post: incoherent
  [SOLVED] UEFI + Fedora Mainline Kernel Booting! cztian 0 4,754 07-13-2017, 08:38 PM
Last Post: cztian
