[SOLVED] UEFI + Fedora Mainline Kernel Booting!
Using DTB file dtb.dtb (Attachment: dtb.zip)
Fedora Version: Fedora 26 RC-1.5
Kernel Version: [    0.000000] Linux version 4.11.8-300.fc26.aarch64 (mockbuild@buildvm-aarch64-02.arm.fedoraproject.org) (gcc version 7.1.1 20170622 (Red Hat 7.1.1-3) (GCC) ) #1 SMP Thu Jun 29 19:59:22 UTC 2017
Problem: Ethernet did not start.
[   31.397491] sun8i-dwmac 1c30000.ethernet: PTP uses main clock [   31.403347] sun8i-dwmac 1c30000.ethernet: no regulator found [   31.409052] sun8i-dwmac 1c30000.ethernet: Will use external PHY [   31.415045] sun8i-dwmac 1c30000.ethernet: Current syscon value is not the default 6 (expect 0) [   31.433727] sun8i-dwmac 1c30000.ethernet: EMAC reset timeout [   31.439466] sun8i-dwmac: probe of 1c30000.ethernet failed with error -12
Update: Using dtb file included in the kernel-core package solved this problem.
.zip   dtb.zip (Size: 2.52 KB / Downloads: 739)
  Pine A64+ mainline mipi-dsi Learnincurve 3 12,268 01-12-2021, 07:36 AM
Last Post: Learnincurve
  Fedora 32/CentOS 8 Pine A64+ Images wideawake 2 10,528 10-02-2020, 11:38 AM
Last Post: mathiraj
  PineA64+: Audio in 5.0 Kernel puzzles 6 16,676 11-13-2019, 09:41 AM
Last Post: roel
  +PINEBOOK Fedora 30 on Pinebook sdgathman 0 6,433 08-14-2019, 11:41 AM
Last Post: sdgathman
  +LTS/SOPINE +PINEBOOK Mainline Armbian for A64 boards Luke 0 4,371 01-12-2019, 06:35 AM
Last Post: Luke
  Fedora 27 on Pine64 gregjo 18 56,743 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Rockpro64 NFS root mount (kernel 4.20) - ethernet help? tenspd137 0 4,925 12-06-2018, 01:14 AM
Last Post: tenspd137
  NVMe and new kernel bjbb17 0 4,383 09-25-2018, 03:39 PM
Last Post: bjbb17
  Real-time linux kernel Artyom 45 124,107 09-11-2018, 01:08 AM
Last Post: zzwpine
  DKMS on kernel 3.10.107-pine64 obrienmd 5 14,485 06-21-2018, 05:45 PM
Last Post: evilbunny
