Home Assistant Supervisor for rock64
Hi everyone, I'm Paolo and I'm Italian and sorry for my English, I wanted to install Home Assistant Supervisor on the rock64 with 4gb of ram but all my attempts failed; could someone kindly help me figure out which version of linux to install and what other steps I need to take to install it? i tried to use Armbian_21.05.1_Rock64_buster_current_5.10.35.img but then when i proceed with this:
1) sudo apt-get update && sudo apt-get upgrade -y
2) sudo apt-get install jq wget curl avahi-daemon udisks2 libglib2.0-bin network-manager dbus apparmor -y
3) sudo apt --fix-broken install
4) sudo reboot
5) curl -fsSL get.docker.com | sh
6) wget https://github.com/home-assistant/os-age..._armv7.deb
here is the error ....
7) sudo dpkg -i os-agent_1.2.2_linux_armv7.deb
thanks to those who can help me  Smile
Hi Karbon,
Try DietPi and install Home Assistance from there.
Paolo,
You didn't actually post the error, mate! Wink
Also, I'm pretty sure that Home Assistant is available in armbian-config, if so that will likely be the easiest way. Although I am not sure if that includes the Supervisor component, or if that is a separate thing.
(02-22-2022, 01:20 PM)helpmerock Wrote: Try DietPi and install Home Assistance from there.
I can't swear to it, but I want to say that DietPi is actually downstream from Armbian on Rock64.
Cheers,
TRS-80
Protocols, not Platforms
(02-22-2022, 01:20 PM)helpmerock Wrote: Hi Karbon,
Hello installed DietPi and performed all the steps and Home Assistant seems to be installed correctly, but does not start at 192.168.1.9:8123
root@DietPi:~# sudo dpkg -i homeassistant-supervised.deb
Selezionato il pacchetto homeassistant-supervised non precedentemente selezionato.
(Lettura del database... 18943 file e directory attualmente installati.)
Preparativi per estrarre homeassistant-supervised.deb...
[warn]
[warn] If you want more control over your own system, run
[warn] Home Assistant as a VM or run Home Assistant Core
[warn] via a Docker container.
[warn]
Viene aggiunto "deviazione di /etc/NetworkManager/NetworkManager.conf in /etc/NetworkManager/NetworkManager.conf.real da homeassistant-supervised"
Viene aggiunto "deviazione di /etc/NetworkManager/system-connections/default in /etc/NetworkManager/system-connections/default.real da homeassistant-supervised"
Viene aggiunto "deviazione di /etc/docker/daemon.json in /etc/docker/daemon.json.real da homeassistant-supervised"
Viene aggiunto "deviazione di /etc/network/interfaces in /etc/network/interfaces.real da homeassistant-supervised"
Estrazione di homeassistant-supervised (1.1.0)...
Configurazione di homeassistant-supervised (1.1.0)...
[info] Restarting NetworkManager
[info] Restarting docker service
PING version.home-assistant.io (172.67.68.90) 56(84) bytes of data.
64 bytes from 172.67.68.90 (172.67.68.90): icmp_seq=1 ttl=55 time=20.8 ms
--- version.home-assistant.io ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 20.828/20.828/20.828/0.000 ms
[info] Install supervisor Docker container
[info] Install supervisor startup scripts
[info] Install AppArmor scripts
[info] Start Home Assistant Supervised
[info] Installing the 'ha' cli
[info] Within a few minutes you will be able to reach Home Assistant at:
[info] http://homeassistant.local:8123 or using the IP address of your
[info] machine: http://192.168.1.9:8123
root@DietPi:~#
after the command: sudo dpkg -i homeassistant-supervised.deb asks me to select the machine type, I tried with raspberry 3, which is the correct one for rock64?
[warn]
[warn]
root@DietPi:~#
cheers, up and running, with DietPi v8.1.2v
Hello everybody
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 19,056 06-27-2026, 02:43 PM
  rAudio for Rock64 V2/Pine A64+ shinzuka 11 2,131 06-25-2026, 03:16 PM
Last Post: shinzuka
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,259 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 6,236 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 12,188 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,323 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,509 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,461 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 87,993 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 111,389 09-01-2024, 06:05 AM
