Bash prompt temp batery Mobian ppp
Hi .
Well i was trying Mobian  and i love the little tweak of adding on .bashrc the battery prompted when ssh connection.
and i realize the path have change and  variables and so, and still there is no wiki so i will share here.
The new thing is just adding and change a couple of things, here we go:
I just create a var.  CAPACI and call it with the new  path.
# -= start battery prompt =-
battery_status(){
BATTERY=/sys/class/power_supply/rk818-charger/ #meu ppp ficar vari CAPACI nou path
CAPACI=/sys/class/power_supply/battery/ # mee ppp crido CAPACI nou path
BATSTATE=$(cat ${BATTERY}/status)
CHARGE=$(cat ${CAPACI}/capacity)
rest of the code dont change.
note:  powersuply app happens the same.
that's it. Should work with this.
ello.
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 14 1,865 10 hours ago
Last Post: diederik
  Disable the GDM service in Mobian. mburns 0 467 11-25-2023, 10:19 PM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 889 11-18-2023, 08:21 AM
Last Post: crocspot
  Fix the Mobian Weather App mburns 0 500 11-07-2023, 10:01 AM
Last Post: mburns
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 710 11-07-2023, 09:44 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 601 10-14-2023, 11:57 AM
Last Post: mburns
  Mobian libnotify custom notifications MadameMalady 5 1,404 08-01-2023, 08:51 AM
Last Post: MadameMalady
  Mobian .desktop file creation MadameMalady 15 3,177 07-27-2023, 04:12 PM
  XFCE mobian running nicely but some oddities grump_fiddle_reinstall 0 804 07-01-2023, 08:18 AM
  [Mobian] : Battery consumption and OS compatibility freelectro 2 1,081 06-02-2023, 06:55 AM
Last Post: Fred Zyphal
