5v|batt jumper next to Pine logo on the Pine64+ board
I am having trouble finding the 5v|batt jumper (the one next to the PineLogo) on the schematics !
... can someone tell me where it's located on the sheets?  tnx.
Also, does that jumper need to be moved in order to use the batt|charger ?
tnx, again.
Beware that there is 2 PCB revisions, one for 1GB RAM and one for 2GB RAM.
But we have only access to 1GB revision schematic, the 2GB still need to be published.
Maybe there is no such jumper on the 1GB, someone would have to confirm that (since I've 2GB version too)
@tllim, do you got any news when the 2GB schematic will be published ?
(06-30-2016, 10:47 AM)MarkHaysHarris777 Wrote: I am having trouble finding the 5v|batt jumper (the one next to the PineLogo) on the schematics !
tnx, again.
I can't see it either, so if it is there they did a good job of hiding it! Smile I can tell you though that the jumper when in the DC5v position connects DC in and 5v on the euler bus together. When you are running just from the battery, it looks like the BAT position connects a booster circuit to the 5v pin to step up the 3.7 nominal voltage of the battery up to 5v for the 5v pin. I
When pine64 from a battery only (no usb lead plugged in / or not powered) that it doesn't matter where the jumper is... it will work even with the jumper removed. So it *looks* like the only purpose of the jumper is to either source 5v from the microUSB or DC in pins, or from a step up circuit when battery powered.
Thanks mates ! ... makes sense. Looking forward to being able to compare the 1G schematics with the 2G schematics. I have been receiving questions about whether its 'ok' to power the board from the 5v pin on either the Euler bus, or the PI bus; without harming the power circuit/ was wondering how the jumper worked into that scenario.
tnx again.
(06-30-2016, 11:51 AM)martinayotte Wrote: Beware that there is 2 PCB revisions, one for 1GB RAM and one for 2GB RAM.
hi martinayotte, I got a pic from Xalius of the 1G board; no jumper !  (no wonder I can't find it on the schematics!) ... doh.
by the by, you ought to join us on the irc channel sometime; your insights would be very welcom.
irc.pine64.xyz:6667    #Pine64
marcus
(07-01-2016, 11:14 AM)MarkHaysHarris777 Wrote: hi martinayotte, I got a pic from Xalius of the 1G board; no jumper !  (no wonder I can't find it on the schematics!) ... doh.
marcus
Doh! indeed... well, that explains it! Big Grin
Er... does he have a different 1G board? I'm pretty sure mine is a 1G - (1GB memory is the identifier, isn't it?), and it does have the jumper... maybe that is one of the differences between Rev A and B? I have a Rev B board (A64-DB-RevB 2016-02-24) (I'll edit this post shortly with a link to a pick), and it has the header???
Photo on Flickr
MemTotal:        1003836 kB
MemFree:          581732 kB
(07-03-2016, 07:22 AM)martinayotte Wrote: @tllim, do you got any news when the 2GB schematic will be published ?
Still in my to-do list, I will push the engineer and get this done on this week.
thanks tllim
Big Grin
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 6,895 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 36,630 12-19-2020, 09:53 PM
Last Post: evilpete
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 5,180 06-04-2018, 03:11 PM
Last Post: marcelser
  solar power on a Pine64 tablet Little_Johnny 11 27,332 03-20-2018, 12:01 AM
Last Post: pfeerick
Sad Fried Pine64 Israeldelamo 0 4,366 07-24-2016, 12:42 AM
Last Post: Israeldelamo
  DC Power IN Power-ON Switch Reset Switch -- Batt Required MarkHaysHarris777 6 18,918 06-25-2016, 01:17 AM
Last Post: xalius
  Can I Use 2 Pine Power Supplies on 1 Pine A64 Board Using the Euler Port? Bob123456789 2 7,924 05-10-2016, 05:48 PM
Last Post: Bob123456789
  Power Pine64 via GPIO dulasu 15 43,258 05-06-2016, 04:24 PM
Last Post: xmasone
