Keyboard causes Pinephone brick?
When I connected the keyboard to my Pinephone, the keyboard didn't work after booting up PostmarketOS 21.12 SXMO. Then after rebooting, the phone hasn't worked again, it's hard bricked. Has this happened to anyone else?
The LED goes from red to amber to white, the phone vibrates, then turns off.  I've tried booting off eMMC, a different SD card, disconnecting the battery, and nothing works, the phone is 100% dead.
I wonder if I got a bad unit, or if this happened due to some HW/SW interaction with the keyboard battery.
That's very concerning. Sorry to hear about your PinePhone. If you have a multimeter or voltmeter or know someone who knows how to use one, it might be worth trying to measure the voltage the keyboard battery is putting out. If it's much too high for some reason, that could explain it.
Make absolutely sure the multimeter is set to measure volts and not current or you could short the battery out!
(01-23-2022, 09:33 AM)acid andy Wrote: That's very concerning. Sorry to hear about your PinePhone. If you have a multimeter or voltmeter or know someone who knows how to use one, it might be worth trying to measure the voltage the keyboard battery is putting out. If it's much too high for some reason, that could explain it.
I'll take some measurements tomorrow and post the results. The phone was from the PmOS batch, which was HW revision 1.2b.
I've also messaged Pine64 support to see if this is a known issue.
Pleas get us informed as i have a keyboard too that is not working but my phone still works after connecting the keyboard.
  Case for Pinephone totilele 13 7,307 04-11-2024, 11:48 AM
Last Post: gramonyl
  keyboard case charging but not typing new2pinephone 18 5,826 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 8,840 01-14-2024, 03:34 PM
Last Post: acid andy
  PinePhone Dock with laptop? Mikey1977Y2J 2 644 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  I've added an I2C connector to the PP keyboard eugenr 0 436 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,208 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 457 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,248 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 525 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 621 10-21-2023, 02:55 AM
