UART switch Pinebook 11.6"
Hi all,
I am trying to resurrect my 11.6" Pinebook, so expect some more posts shortly.
For debugging, I would like to know the position of the tiny switch inside the case that switches between UART and headphone audio.
I have searched, but I can't find a definitive answer, and I can't remember if I already moved the switch...
So, there are two positions. Inboard (towards the centre of the laptop) and outboard (towards the, er, edge of the laptop). Which position is UART please?
Yes, I could figure it out if I could boot up...
Thanks!
Ok. I can boot. Opening the case, staring at the innards really hard, and putting the cover back on helped.
The initial problem was that the KDE neon logo would appear (concentric circles) then the screen went black. I couldn't even get a console, and booting from SD card failed also.
After peering inside (and doing literally nothing) I tried booting again. This time I was able to switch to a console, whereupon I learned that the eMMC was full and the OS was thrashing.
Next, I reflashed my SD card (with the 1080p version of Neon) using dd on a Raspberry Pi because Etcher on my PC was a bit sus. Rebooted with that and... success!
I've set up Neon, but I think I just did it on the SD card. I haven't figured out how to rewrite the eMMC.
But, I digress, this thread was supposed to be for the UART switch.
Thanks.
(01-01-2022, 08:17 PM)irongarment Wrote: For debugging, I would like to know the position of the tiny switch inside the case that switches between UART and headphone audio.
Thanks!
So which direction of the switch is UART and which direction is audio out? Just for future reference, someone else might need that same info....
Quote:So which direction of the switch is UART and which direction is audio out? Just for future reference, someone else might need that same info....
Umm... I don't have the information. I was hoping someone could provide it. For future reference. Which is why I asked.
I suppose I could figure it out for myself, now that I can boot, but there really ought to be documentation somewhere (and no, the schematic doesn't count).
In this video the Pinebook is being opened in what I assume is stock condition and you can see the switch in the outwards position, so I guess outwards is headphones and inwards is UART.
  Anyone selling a Pinebook ams 1 353 06-04-2025, 10:10 PM
  pinebook 1080p power/barrel connector/cable cel 0 1,188 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 2,028 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 1,923 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 2,852 06-07-2022, 10:35 PM
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 3,614 09-25-2021, 12:03 AM
  Pinebook 14 " Battery Swollen/Bulged billjon 1 4,668 01-13-2021, 11:03 AM
Last Post: barray
  touchpad on pinebook issues? ron_burgundy 14 17,984 12-19-2020, 06:55 PM
Last Post: ron_burgundy
  Pinebook doesn't charge anymore Reinoud 0 3,349 08-20-2020, 08:18 AM
Last Post: Reinoud
Information How To Setup Serial Console Cable Over the Pinebook MarkHaysHarris777 4 25,921 07-02-2020, 06:33 PM
