Screen/display gets switched on by itself / Phone wakes up from suspend
Since a while my phone does not remain in standby: For some reason (without any messages coming in etc.) the screen switches itself on and either the lockscreen (with time, date, connections) is visible or the screen is black, but on (i.e. not switched off but displaying a black surface, as you can tell by the glow).
This of course drains huge amounts of energy and reduces the standby time from two days to a few hours.
Other than the power settings (Screen blank after two minutes, automatic suspend on) I have no idea where to look in order to fix it.
Ideas anyone?
I noticed this within PMOS(edge) but only when having a Waydroid session activated.
(12-29-2021, 04:42 AM)Juergen Wrote: I noticed this within PMOS(edge) but only when having a Waydroid session activated.
I don't know what Waydroid is, but on my phone it also happens when no applications are open at all.
On the advice of knowledgeable people I removed the SD card.
Now the phone sleeps like a baby again. Problem solved, sort of.
If you cannot do without an SD card, downgrading to kernel version 5.13 or 5.10 seems to help.
Basically an Android emulator for Linux distributions that are using Wayland rather than X11.
In the case of the PinePhone, Phosh and Plasma Mobile are using them as the only option, Lomiri uses Mir, and SXMO uses X11 (Wayland version is SWMO).
Any of the desktop ones can be either X11 or Wayland.
母語は日本語ですが、英語も喋れます(ry
(12-29-2021, 03:35 AM)Anna Wrote: Since a while my phone does not remain in standby: For some reason (without any messages coming in etc.) the screen switches itself on and either the lockscreen (with time, date, connections) is visible or the screen is black, but on (i.e. not switched off but displaying a black surface, as you can tell by the glow).
Ideas anyone?
it's this bug here: https://gitlab.gnome.org/World/Phosh/phosh/-/issues/686
  Screen auto-rotation sensitivity mdk 0 271 12-26-2023, 06:08 AM
Last Post: mdk
  Unable to wake up from suspend xavi92 5 1,132 10-26-2023, 03:02 PM
Last Post: xavi92
  Suspend on ram user641 2 713 09-25-2023, 01:44 PM
Last Post: user641
  System won't suspend due to suspention notification user641 6 1,425 09-24-2023, 05:47 AM
Last Post: user641
  Power Consumption on Suspend JudgeFudge 8 1,867 07-29-2023, 06:24 AM
Last Post: JudgeFudge
  Chatty does not work after suspend mode user641 4 1,932 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  Screen stay black unless power key pressed short freelectro 0 652 06-24-2023, 01:55 PM
Last Post: freelectro
  Unsuspend → Black screen mdk 15 5,218 06-22-2023, 11:20 AM
Last Post: Melechtna
  Mobian + phosh firefox ublock and other overlays display bugs tuxcall 3 1,799 02-24-2023, 12:11 AM
Last Post: nexion
  Lock screen question: always squeekboard tuxcall 1 1,233 02-02-2023, 08:51 PM
Last Post: Haibara23
