Suspend on ram
Is there a way to set suspend on ram, like what purism did to the L5? It seems to improve battery life a lot.
The PinePhone should already be set up to suspend to RAM on inactivity. I have not checked whether Mobian sets it up correctly, but in principle any PinePhone distribution should be set up for it.
Hibernate (suspend to disk) is not possible without a physical swap partition, and since the PinePhone distros apparently all use only zram for swap (because swap on SSD tends to wear out the SSD, that goes for both the eMMC and any microSD card), there is no way hibernate can work. So suspend to RAM is the only option, which everyone should be using already.
(09-24-2023, 01:13 PM)Kevin Kofler Wrote: The PinePhone should already be set up to suspend to RAM on inactivity. I have not checked whether Mobian sets it up correctly, but in principle any PinePhone distribution should be set up for it.
Thanks for the detailed answer.
  Unable to wake up from suspend xavi92 5 1,138 10-26-2023, 03:02 PM
Last Post: xavi92
  System won't suspend due to suspention notification user641 6 1,433 09-24-2023, 05:47 AM
Last Post: user641
  Power Consumption on Suspend JudgeFudge 8 1,873 07-29-2023, 06:24 AM
Last Post: JudgeFudge
  Chatty does not work after suspend mode user641 4 1,948 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  suspend inhibit no longer working jsch 3 1,993 10-23-2022, 09:20 AM
Last Post: LibrePhoneUser
  Suspend broken on the pp user641 0 849 04-08-2022, 04:18 PM
Last Post: user641
  Screen/display gets switched on by itself / Phone wakes up from suspend Anna 5 4,063 01-04-2022, 01:24 PM
Last Post: pothos
  Eliminate swiping/logging in when waking up from suspend? Zebulon Walton 5 4,115 08-13-2021, 06:15 PM
  Prevent suspend during active call ergo owl 2 3,054 09-11-2020, 04:36 AM
Last Post: ergo owl
  Prevent suspend & keep the screen spaetz 1 2,610 08-29-2020, 01:13 PM
Last Post: devrtz
